Power door lock elec. problem
Old Mar 3, 2015 | 04:14 PM
MSD's Avatar
MSD
Hello All,
I have a 2002 F350 Lariat. Every couple of months I have to disconnect the batteries to re-set my door locks. It seems they stop working while everything else still works.
At first I thought it was the typical door ajar problem but the power lock button on the doors wouldn't work, and the key fob didn't unlock the doors either.
After disconnecting the batteries for another repair, the locks worked again.
I have used this "fix" a couple of times since. Always works but something is wrong.
Anyone have the same experience and a fix?
Thanks
Old Mar 3, 2015 | 04:49 PM
aaronbob's Avatar
aaronbob
https://www.ford-trucks.com/forums/9...-pictures.html
mine were slugish and this fixed them and they worked like new ever since
Old Mar 3, 2015 | 04:52 PM
whitetmw's Avatar
whitetmw
Originally Posted by MSD
Hello All, I have a 2002 F350 Lariat. Every couple of months I have to disconnect the batteries to re-set my door locks. It seems they stop working while everything else still works.
At first I thought it was the typical door ajar problem but the power lock button on the doors wouldn't work, and the key fob didn't unlock the doors either. After disconnecting the batteries for another repair, the locks worked again. I have used this "fix" a couple of times since. Always works but something is wrong. Anyone have the same experience and a fix? Thanks
The only thing that comes to mind is the VSS Module.
Do you have any historic DTC's?
Old Mar 4, 2015 | 07:42 AM
MSD's Avatar
MSD
Hi whitetmw,
Does VSS stand for variable speed sensor? If so, I don't see the connection to my power door locks. As for "DTC's", I'm not sure what that is.
Aaronbob, my door locks just don't work at all when this happens. It's as if the power has been cut off from them and the switch. I can only operate them manually.
Old Mar 4, 2015 | 08:29 AM
whitetmw's Avatar
whitetmw
Hi whitetmw,
Vehicle Security System. Ford transitioned to the VSS from the GEM in 01/02.
Old Mar 4, 2015 | 09:56 AM
holeshotwalt's Avatar
holeshotwalt
Diagnostic Trouble Codes- use a code reader in the OBD2 connector to check any new or stored codes.
Old Mar 28, 2015 | 06:28 AM
MSD's Avatar
MSD
Just to update everyone.
I just had the Vehicle Security Module replaced by my local Ford dealership. Cost was $632. Ouch.
However, I did learn something that might help others:
1. My 2002 F350 has both a GEM and VSM. I asked to have the VSM replaced and the service writer said no, you need the GEM replaced, which they had to order. Ok. Fortunately, the mechanic questioned that because he has replaced many more VSM's than GEM's.
sxrfun
Sep 15, 2015 08:17 AM
bryyce62
Oct 9, 2011 07:47 PM
gjnicholas
1978 - 1996 Big Bronco
May 7, 2010 08:53 PM
jetjock16
Mar 15, 2005 08:33 AM
laha
Jan 28, 2003 05:00 PM
