First long tow update
Old Mar 29, 2015 | 12:51 PM
efx4's Avatar
efx4
I have to believe the Yukon weighs less than the F-150, and the tow mirrors don't help with wind resistance either. I tow over 8000 lbs. and get between 8-9 mpg, and if I tow above 70 mph. its less. I too have the Eco with 3:73's with a 6.5' bed, and that comes at a fuel economy penalty. My old 2010 FX4 with the 5.4 V8 towed my trailer with little power reserve and at around the 7 mpg range, so the ECO or BOOST engine isn't that bad of a trade off.
Old Mar 29, 2015 | 12:55 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Originally Posted by Tom
But what's the profile of that trailer? I've always disliked the way people equate weight with fuel economy, because it's only part of the story. On the highway it's much less meaningful than wind resistance.
On the highway you will get better fuel economy with a low-profile 10,000 lb trailer than you will a 3,000 lb full-profile enclosed trailer.
It was a like a contractors trailer that I borrowed from my neighbor last summer to help another friend move to a neighboring city about 25 miles away. I had to make two trips with this set up. The trailer is a tandem axle and the roof line is higher than my truck.
I get what you're saying, I should have been more clear. But, the fact remains and we've agreed on this in the past, the 3.31 axles are plenty behind the ecoboost for lighter work and daily driving.
Old Mar 29, 2015 | 12:58 PM
Tom's Avatar
Tom
Absolutely.
Old Mar 29, 2015 | 01:46 PM
bakon's Avatar
bakon
Originally Posted by Izzy351
Boost, but not RPM. The EcoBoost has WAY more low-end torque than the other engine options, more like a diesel. Everything else being equal, the EB won't have to downshift to keep moving where the other NA motors will. Yes, it takes fuel, but so does downshifting and pulling hills at 4000 RPM.
To the OP, are all these mileages you list hand-calculated or are you relying on the lie-o-meters?
We are probably talking different things here. I am referring to general principle of physics of the motor to produce power, comparing each other. You are correct at where ecoboost produces power relative to the NA engines including the 5.0. much lower But to make power at 1.5 liters smaller than 5.0 or 1.8 smaller than Chevy 5.3, it uses boost to add more air and fuel. Given the 10:1 compression the boost actually makes the compression higher than the 5.0 10.5:1 ratio to produce the basic power needed. Without boost, the rpm would need to be higher to make up the basic displacement loss. But I see your thinking of less rpm, less fuel, its just not the case if trying to produce power vs riding along at 70 at light throttle.
All things are never equal- displacement size, compression ratio, cam timing and then throw in boost and everything is out the window. But the same theory applies in producing any power, fuel and air, its just how much...
And a new set up is only better than the old engines in improving intake and resulting output. Adjusting intake runners, timing, boost, that's the trick to fuel economy year to year. You are right, I was just off in another field...
General outline...
Producing More Engine Power - HowStuffWorks
Old Mar 29, 2015 | 04:55 PM
seventyseven250's Avatar
seventyseven250
I agree with this. For my uses, it's a GREAT trade-off.
Old Mar 29, 2015 | 06:03 PM
Izzy351's Avatar
Izzy351
General outline...
I'm tracking. All I was saying is that the EB is peaking for torque around 2000-2500 RPM, so it can sit there and pull at that RPM vs. the NA engines that need to downshift to get back in their torque peak of 4000. The EB will just add fuel & build boost to maintain speed up a hill instead of downshifting. That's what I meant by "all other things equal"...
Check out the Ike Gautlet runs with the EcoBoost on YouTube. Pretty impressive.
Old Mar 29, 2015 | 08:43 PM
GuyGene's Avatar
GuyGene
Bakon, whew, when yall boys go to digging that deep in physics mumbo jumbo, I'm outta here. Me old haid cain't take it. I'm with old Red of Red/Green show. He speaks me language.
howellt39
2009 - 2014 F150
23
Mar 30, 2013 12:58 AM
BLK94F150
2009 - 2014 F150
16
Dec 21, 2011 08:26 AM
EXCURSIONATOR1
Aug 19, 2011 07:51 PM
bobbyrjw
22
Jan 30, 2011 08:30 PM
TurtleRacing
17
Dec 13, 2006 03:57 AM
