Transmission leak
Old Mar 25, 2015 | 03:55 PM
jayjjcc's Avatar
jayjjcc
Transmission leak
I've seen this talked about before and it's happened to me before aswell but now the tranny is leaking onto my Ypipe a couple times per week and it's giving me a hard time when I try to reverse. revs drop and it stalls if I don't give it enough gas.
So I know I have to change the seal but Ford is telling me the torque converter will need to be replaced but another transmission shop told me once the seal is changed and fluid level set appropriately I shouldn't have the reversing problem anymore?
Is this something I could attempt myself... looks almost like I'd have to move the exhaust to drop the tranny...
Old Mar 25, 2015 | 07:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the torque converter hub doesn't have any damage you can reuse the converter. If the surface has damage you need a new converter. I don't know if you can do it yourself or not. Be aware that the trans weighs 270 pounds. The transfer case adds more weight.
Old Mar 25, 2015 | 07:53 PM
jayjjcc's Avatar
jayjjcc
But could the stalling in reverse issue be caused by the seal leaking?
Old Mar 25, 2015 | 09:30 PM
Mark Kovalsky
Not directly. It could if the leak lowered the fluid level enough.
Old Mar 25, 2015 | 11:29 PM
jayjjcc's Avatar
jayjjcc
It's not simple to check the fluid level though... you drive for a bit, park and check level... add a bit and then you can't check it anymore because it's cold and the fluid is like molasses and won't drip all the way down for days. When you check all you see is a dipstick with 2 feet of red goo hanging off of it...
I've been trying to buy a 2nd X to run while I work on this one... but all I can find in my budget range are ones with 500k+ kilometers... and to be honest... I think that's quite alright
But this transmission leaking/reverse stalling thing has been the most tedious thing I've had to deal with up to now... I don't want to pay $500 to change a $30 seal...
Old Apr 6, 2015 | 12:03 PM
jayjjcc's Avatar
jayjjcc
Mark, if I try and tackle this myself (I'm currently not working until June so I have plenty of time) what parts will I need? I see the viton seal is the one I should get... but I've read something about changing bushings or some copper piece while I'm in there?
Old Apr 6, 2015 | 01:01 PM
Mark Kovalsky
You need the Viton seal, a torque converter hub bushing, and a pump seal and gasket. All together these parts should be no more than $30.
If the torque converter hub is damaged you'll need a new torque converter, too.
Old Apr 6, 2015 | 08:37 PM
jayjjcc's Avatar
jayjjcc
If I go to my local Ford dealership will they sell me a viton seal? Do I need to ask for it specifically or is it only an aftermarket seal?
Old Apr 29, 2015 | 10:11 PM
jayjjcc's Avatar
jayjjcc
What is the name of this seal exactly? The only Viton seal on Rockauto I can find is a crankshaft seal...
Old Apr 30, 2015 | 10:09 AM
Mark Kovalsky
Torque converter hub seal. I usually get trans parts at Home - Transtar Industries.
Old Apr 30, 2015 | 11:09 AM
J ballan's Avatar
J ballan
If your tranny is low enough to cause trouble when going into reverse you need to get the level back up the the full hot mark ASAP or you could cause major damage to your tranny. Also usually when transmissions are low they will slip or take a long time to go into gear not stall the engine. That sounds like a separate issue IMHO.
Old Apr 30, 2015 | 02:55 PM
Mark Kovalsky
Low transmission fluid WILL cause an engine stall. When the fluid is low line pressure drops. The main regulator valve has a priority function that will cut off the pressure feed to the torque converter when line is too low. Without pressure to hold off the converter clutch it can drift on and that will stall the engine. That's a fact, not MHO.
Old Apr 30, 2015 | 04:22 PM
J ballan's Avatar
J ballan
Wow I've never seen that before. Learn something new every day. Either way he should correct the fluid level right quick before he causes more damage.
LostinFord20
Apr 11, 2012 08:03 AM
nsaikia
Apr 1, 2008 09:06 AM
DonniW2448
Aerostar
Jul 20, 2006 06:59 AM
K's Daddio
Modular V10 (6.8l)
Jul 4, 2006 03:32 PM
Chambord69
Aug 27, 2003 11:40 AM
