Isolator troubles
Old Mar 25, 2015 | 10:49 AM
Topkat69's Avatar
Topkat69
Isolator troubles
Over the weekend I was driving my 2000 F350 and the alternator died (found out later). The shop said they replaced the alternator but it wasn't charging. They later told me it was because the isolator failed. My 2nd battery WAS a yellow gel battery. Before the battery (in series) was an 50 amp circuit breaker...........that blew apart.........and the battery had a melted off side terminal. It looked like the 'sealed gel battery" had been 'leaking for a while" (as there was funky acid type white corrosion deposits in a few places.
Any speculation what happened here?
thanks as always!
Tk
Old Mar 25, 2015 | 11:27 AM
Tim Hodgson's Avatar
Tim Hodgson
What are you referring to as an "isolator." Do you/did you have a two battery setup with a "starting" battery-ies and a "house" battery-ies connected by something like a SurePower isolator or separator?
I may be able to point you in the right direction but more description of your set up is required.
Old Mar 25, 2015 | 12:39 PM
Topkat69's Avatar
Topkat69
A 3 post Surepower isolator. 2 batteries. 1 for staring the truck the other runs my rear flood lights, a 1500 watt inverter, and my cb radio.
Old Mar 25, 2015 | 12:59 PM
Tim Hodgson
If you are interested, here's a little reading for you:
Sportsmobileforum.com ? View topic - Battery Isolators,Separators, and Switches?
Sportsmobileforum.com ? View topic - Comparing the Blue Sea 7611 to the Surepower 1315
Sportsmobileforum.com ? View topic - Sure Power Isolator to Blue Sea 7622
You may have to join to pm him, but Scalff77 is an electrical engineer and helps out with the SurePower issues which alot of members on the sportsmobileforum.com have had.
Sportsmobile's have starting batteries and house batteries often separated by a battery separator or isolator (those two things are different). I had one. And threw it away. But talk to Scalff77 about it by pm'ing him or maybe sharing your experience by posting in one of the established threads.
Old Mar 25, 2015 | 02:18 PM
Franklin2's Avatar
Franklin2
I would say your battery failed and shorted, blew apart the circuit breaker and burnt out the isolator.
bismic
Oct 27, 2022 07:08 PM
wingerpaul
Nov 1, 2008 12:07 PM
BIG-COUNTRY
Electrical Systems/Wiring
13
Jan 2, 2006 11:50 AM
Billy Brethren
18
May 3, 2005 12:05 AM
slifer
May 16, 2004 04:44 PM
