AirBag OCmpressor- Location
Old Apr 11, 2015 | 12:26 AM
Fordsdad's Avatar
Fordsdad
Mine is in the jack area as well. It is a loud but its only on for a short time when needed.
Old Apr 11, 2015 | 05:41 AM
IMASAP's Avatar
IMASAP
Curious which compressor you got. Plumbing it directly to the bags, or going to have an air tank ?
Old Apr 12, 2015 | 12:36 AM
xplodn's Avatar
xplodn
I have the airlift basic compressor. I went back and forth and then decided to just send it back. I don't want to give up the jack cubbyhole and I didn't want it in the weather. With it being a Cali truck I almost had enough room under The hood but the extra charcoal canister is just enough in the way to be annoying.
I am just going to need to pump them up like the fronts which is going to need to be fine.
Old Apr 12, 2015 | 07:50 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
Mounted mine under the drivers seat between the frame rail and the steps. I decided to mount them vertically for better longevity. Also used a piano hinge so I can loosen a couple bolts on the frame and the entire thing pivots down for any maintenance.
Old Apr 12, 2015 | 08:39 PM
IMASAP's Avatar
IMASAP
Wow !! Dueling compressors. Very nice install.
Old Apr 13, 2015 | 08:43 AM
Air Lift Company's Avatar
Air Lift Company
Former Vendor
Just food for thought.. We do not recommend putting the compressor under the hood. The compressor will constantly be pulling in hot engine air which will shorten the life of the compressor.
Old Apr 13, 2015 | 08:13 PM
xplodn's Avatar
xplodn
Not waterproof and can't take the under hood heat, hmmmmm. I like airlift stuff certainly but I'd really like to see a waterproof version.
Old Apr 13, 2015 | 10:31 PM
ScaldedDog's Avatar
ScaldedDog
I don't know about waterproof, but mines been mounted under the AC unit behind the mud flap for a dozen years, or more, with no issues.
Mark
Old Apr 15, 2015 | 01:14 PM
Air Lift Company
Former Vendor
As would I, but we do not make the compressors at all. Mine has been mounted on the inside of my frame rail for 7 years through Michigan winters without any issue. Just because the compressor is not waterproof does not mean it cannot get wet. You just do not want to completely submerge the compressor, that will ruin things.
Hitagain
Feb 18, 2016 04:46 PM
Peavey1986
Jun 8, 2015 09:25 PM
burk4175
Sep 17, 2014 02:33 PM
racert17
May 9, 2013 07:14 PM
robl74
Dec 12, 2010 08:47 AM
