Bronco II Ford Bronco II
Fuel Pump
Old Jul 24, 2003 | 10:48 PM
84bronco2's Avatar
84bronco2
From: I live in the beautiful state of hawaii, on the island of Oahu
Fuel Pump
I am trying to replace the fuel pump on my '84 bII...I can't reach the bottom bolt on the fuel pump
any suggestions on how to reach it.....and what size it is
if any of you can help me that would be great
Old Jul 24, 2003 | 11:31 PM
Willy McCoy's Avatar
Willy McCoy
Fuel Pump
When I replaced mine, I removed the oil pressure gauge sender and the pipe it screws into. Then after removing the fuel lines, I used a 13mm "wiggle" (universal) socket at the end of a long extension.
Hope this helps
Old Jul 24, 2003 | 11:34 PM
84bronco2's Avatar
84bronco2
Fuel Pump
the oil pressure gauges...thats right below the fuel pump?
Old Jul 25, 2003 | 06:25 PM
Willy McCoy
Fuel Pump
It's been a couple of years, but that oil pressure sender and it's connected pipe sure interfere with getting at the fuel pump. I removed mine from up top if that makes a difference.
Old Jul 27, 2003 | 08:01 AM
84bronco2's Avatar
84bronco2
Fuel Pump
well i finally got that fuel pump on and working....but my bII still has a HUGE hesitation in accleration........any suggestions on what It might be...
I have replaced the spark plugs & wires, fuel filter, fuel pump....
HELP!!!
Old Jul 28, 2003 | 04:24 PM
WeWonIt's Avatar
WeWonIt
Fuel Pump
I am just stating the obvious but some times it helps. Check your air cleaner & breather hose, and another Idea is to clean your fuel system & tank, I used Barrymans B-12 Chemtool its old school but it works. any sediments, rust or dirt will clog the lines. Is 84 a carb or fuel injected either way clean the fuel distribution area such as the throttle body or carb. If your problem is not that simple move on to your ignition system: timing, distributor or coil. That is my opinion anyway, hope it helps
albinorhino
Jan 14, 2017 06:10 PM
cliffordingles
Jun 8, 2016 06:42 PM
84 f250 6.9
45
Feb 1, 2011 12:48 PM
lovinmytruck
19
Feb 21, 2010 09:56 AM
slimbronco
Bronco II
Oct 30, 2004 10:28 AM
