need help installing
Old Mar 23, 2015 | 12:13 PM
classic_custom 79's Avatar
classic_custom 79
I am trying to install a new pioneer head unit but I cant seem to find were to connect my remote wire
Old Mar 23, 2015 | 12:54 PM
4x4slik's Avatar
4x4slik
The remote wire, usually blue, is to activate an accessory, such as a power antenna or an amp. Not needed to simply hook up a stereo.
Old Mar 23, 2015 | 12:57 PM
classic_custom 79
So then how do I hook up my amp to it for my remote I dont want it to constantly suck energy from my battery
Old Mar 23, 2015 | 01:01 PM
4x4slik's Avatar
4x4slik
Oh, you have an amp. You should have a remote terminal on the amp. Got a model number for amp?
Old Mar 23, 2015 | 01:05 PM
classic_custom 79
Yeah its a planet audio amp 2 channel mosfet amplifier 200w x2
Old Mar 23, 2015 | 01:13 PM
4x4slik's Avatar
4x4slik
need a model number, usually consisting of letters and numbers
Old Mar 23, 2015 | 01:21 PM
4x4slik's Avatar
4x4slik
Looked at several planet audio amps (they don't list a 200w amp on their site) and all of them had the remote terminal in between the 12v+ and ground terminal.
Old Mar 23, 2015 | 01:27 PM
classic_custom 79
I cant find the number but it has the remote spot but I need to know were do I connect the remote to in my
dash
Old Mar 23, 2015 | 01:31 PM
TheMonson's Avatar
TheMonson
You don't connect it to the wiring harness (assuming that is what you're asking). You run a wire from the remote terminal on the amp to the remote wire on the head unit.
Old Mar 23, 2015 | 01:33 PM
classic_custom 79
But I dont have my head units remote wire connected I never knew were to connect it so I didn't touch it
Old Mar 23, 2015 | 01:34 PM
4x4slik's Avatar
4x4slik
Ok, you should have a blue or blue/white wire coming from your pioneer head unit. You will run this to the remote spot on the amp. You need to extend this wire from head unit to amp. There are no factory wires for this. The wire should be labeled or id in manual for amp or power antenna or remote.
Old Mar 23, 2015 | 11:05 PM
Jdeshler's Avatar
Jdeshler
I'm sure neither one of these are your exact models but this is how they have to be connected
Good luck
Old Mar 24, 2015 | 12:56 AM
burnthelight88's Avatar
burnthelight88
If you don't have the blue wire coming from your head unit (you really should unless you cut it after you bought it), you can connect the remote terminal on the amp to anything that goes hot with the ignition. Be sure to not connect it to a constant 12v source as that will drain your battery.
newtuner
Feb 24, 2006 12:14 PM
trini boy
Escape & Escape Hybrid
Jul 19, 2004 10:52 PM
chris_n_va
Dec 19, 2002 09:02 PM
oft
Jul 25, 2002 07:26 AM
