RR Wheel speed sensor ground down?
Old Mar 23, 2015 | 11:26 AM
lbiffin's Avatar
lbiffin
I have a 2006 Expedition Eddie Bauer 2wd with the 5.4l Triton. 100k miles.
A little while back i got an ABS light on. Pulled a chassis code for the right rear wheel speed sensor. I replaced it. Cleared the codes and it came right back on without even driving it.
I bought a new sensor to see if maybe i bought a bad one. Plugged it in, cleared the code...and the light stayed off.
So, today, I pull the sensor out to put the newest one in and notice that the end is ground down or broken off. I pulled the original one out of the trash and found it too was ground down or broken. Not sure how i missed it the first time.
Anyways, ive attached a photo so you can see the difference. Any ideas? Thanks for your help. Super Frustrated.
Old Mar 23, 2015 | 11:59 AM
alloro's Avatar
alloro
The hub/wheel bearing is worn and allowing enough play for the tone ring to reach the sensor.
Old Mar 23, 2015 | 12:03 PM
lbiffin's Avatar
lbiffin
Thanks. Wheel hub ordered.
Old Mar 24, 2015 | 09:18 AM
alloro's Avatar
alloro
Did you first confirm it was worn by checking for excessive side to side play? My diagnosis is only a starting point, I can't confirm it myself since I am not there.
louie d
Nov 24, 2015 04:26 PM
meborder
Nov 19, 2015 05:36 PM
eph5vs20
2004 - 2008 F150
Nov 13, 2015 09:57 PM
Cilvers
2009 - 2014 F150
Nov 30, 2014 12:20 PM
mikren
1997 - 2003 F150
Aug 31, 2009 01:09 PM
