Junk block, need a new one
Old Mar 22, 2015 | 05:07 PM
breezesboy's Avatar
breezesboy
Tore down my 351m to find cylinders already bored 030, and in sorry shape. I need an 040 over block. My question is this. Everything I have, cylinder heads, intake, headers, distributer, pistons, crank, gasket sets, galley pan, lifters, rods..... Everything, was for a 351m: can I purchase a 351c and keep all my parts, or will some parts not work?
Old Mar 22, 2015 | 06:28 PM
ZarK-eh's Avatar
ZarK-eh
Not sure, Imma 300ci 4.9L I6 boy... but I did find this: https://www.ford-trucks.com/forums/1...c-vs-351w.html
Old Mar 22, 2015 | 06:41 PM
gatorfor88's Avatar
gatorfor88
Heads will work,intake would have to be shaved,headers would fit heads but might not fit vehicle,dist will work, pistons I think would have to have pin bore resized but not sure,crank I dont think will work,lifters I think will work, rods are totally different. But the main thing is a 351c wont bolt up to a 351m tranny.
Old Mar 22, 2015 | 09:54 PM
Blue and White's Avatar
Blue and White
Will your block clean up at .040" overbore? May be the best option. Or look for a new block. 351m and 400 blocks are the same. If you score a decent 400 with crank, all your heads, mounts ect. will work and you will have a 400 (need 400 pistons though).
Old Mar 24, 2015 | 07:17 AM
breezesboy's Avatar
breezesboy
new block
picked up a new block, but now that creates more questions. I bought a standard bore D7TE-A-2-B, the old block was D7TE-A3B. I know enough to know these are both M truck blocks, but will my accessories, motor mounts, bell housing, pulley brackets etc.....is it all going to transfer over okay?
Old Mar 24, 2015 | 08:23 AM
bkaul's Avatar
bkaul
I don't know part numbers, but if they're both 351/400M blocks, they'll have the same bell housing and motor mount attaching points. It's possible there could be other differences, but those aspects will be the same.
Accessory brackets typically attach to the timing cover/water pump/heads rather than the block itself, but I don't know why that would be any different - look and see.
BensDaddy
23
May 25, 2008 03:35 AM
hurri10209
Mar 22, 2004 06:58 PM
jwtaylor
Dec 24, 2003 05:56 PM
slmd350
Nov 5, 2003 04:57 PM
snekrs_mach1
Mar 3, 2002 06:41 PM
