Does anyone know if it is normal to have lower max boost after installing a billet wheel, ported intake, and EGR delete? I just got the truck back together and while cruising at 65 the boost has increased from 6-7 previously to 8-9 after the upgrades but now my max boost is only 20 whereas it used to be around 28. I'm not sure if it is just moving more air now or if I have a problem to find
Also, after finishing the upgrades listed above, my EGT's while cruising have stayed the same- if not, actually increased. Any thoughts? Thanks!
It's a domino effect. You added the ability for the turbo to spool up faster but took away the egr flow. So now the computer sees low egr flow. Even tho you improved air flow the pcm now only has the one intake sensor to read the flow. Now you get to buy a programmer and have custom tunes wrote for it to use all them goodies. Unless you have a leak somewhere.
I would check and double check all of your turbo connections. Specifically the y-pipe. Is your truck noisier now that work has been accomplished? The y-pipe clamp will not suck the flanges together.
There is only one connection that I have been questioning and that is the y-pipe to turbo connection. When I put it back together, there was an 1/8" gap on the bottom of the connection. Normally when I re-install a turbo, the gap is usually on the top and can be ratcheted together, but in this instance I could not figure out any possible way to close the gap so I clamped it down as tight as I could and hoped that it would work its way together once the y-pipe w/ new flex joints was broken in a little. I don't see any signs of soot though even when I feel around the connection with my hand.
As for being louder, it is hard to tell because I swapped from an 04 turbo to the screaming 03 during the upgrades.
I haven't gotten into modding that much but it seems logical to me. Reducing restrictions will increase flow because there's less to push against. Sorta like how a big high pressure oil leak can cause low pressure oil psi to drop.
Thanks for the help guys! My first thought was that the ported intake created more flow and less pressure- like blowing air through a straw vs a 1" PVC pipe. You have more air pressure in the straw but more flow in the 1" PVC. I have not done a complete re-learn because I thought that was only for 03 motors.
Is your fan control workingproperly? Is your EGR valve still in the intake and it should be plugged in? I agree with previous posters, you do probably need a tune. But, if your not ready for that, clean MAP, and tube, clean EBP and tube, clean MAF, IAT1, and IAT2 and then run the whole relearn procedure. Use MAF cleaner and be careful, gentle. You may ned to soak the tip of the EBP and IAT2 which are in the intake and get sooty. Check for codes, if it still says codes for drive cycle you need to start again. If you are not following a relearn procedure form somewhere I can write it out for you. Let me know.
they way I have found to help line up that y-pipe is:
- loosen marmon clamp
- loosen but not remove manifold to y-pipe bolts
- loosen turbo bolts slightly
- get a small ratchet strap hook it right in the y section (it will friction lock) hook the other side to something stable (i used my brush guard) crank it down.
- check to see that it is flush all around.
- tighten marmon clamp securely, 53 IN-lbs
-re-tighten turbo mounting bolts
-re-tighten manifold to y-pipe bolts
OK guys, I tore it apart today and the y-pipe did appear to be seated properly so I can check that off the books I have already cleaned all sensors that I could possibly find during the upgrades. Currently the EGR valve is removed but after seeing the problems first arrise, I plugged it in and left it rolling in the engine bay and it didn't make any difference except for taking care of a code or two. I found a re-learn writeup that I will try tomorrow. I did do a test tonight and watched MAF at 65mph and it was 155-160 whereas a buddy of mine who has a billet wheel and factory intake only runs 130-140 so I think that proves that I am moving more air than stock even at less boost.
Another thing I may have forgot to mention is that I removed the factory throttle plate assembly and replaced it with an 05 intake elbow if that affects anything
