Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Abs light troubleshooting
Old Mar 21, 2015 | 04:21 PM
DaveTV's Avatar
DaveTV
Hi all - 2005 XLT - ABS/4x4 light on. I had this issue last year, and all said tone rings. They were right, I replaced both tone rings on the front with the help of YOUTUBE and all has been good. We have had a very tough winter, one day after I kinda backed into a soft snowbank, and the light was back on. It was so cold and snowy for so long, my thought was that some snow/ice was interfering with the sensor, and that when things warmed up and thawed out it would go away. We have had some good thaws, and it is still on. I did a visual inspection of the tone rings, the fronts appear good and what I can see of the rears showed no cracks, although on the rear it is hard to see the whole ring at once unless you pull things apart. SO.. my question is, is there a good troubleshooting procedure to ut my finger on exactly what is causing this? Any and all advice appreciated!
Old Mar 21, 2015 | 04:54 PM
projectSHO89's Avatar
projectSHO89
Pull the fault codes from the ABS controller with your scanner. Those will tell you what it's complaining about.
Old Mar 21, 2015 | 05:31 PM
DaveTV's Avatar
DaveTV
Thanks - I had stopped at AutoZone, they do free reads, but he said they can only scan "Check Engine Light" codes, not the ABS light. What tool gives you ABS fault codes, and where would it plug in?
Old Mar 21, 2015 | 07:02 PM
ctubutis's Avatar
ctubutis
Let me google that for you
Old Mar 21, 2015 | 07:06 PM
DaveTV's Avatar
DaveTV
Well thanks for the smart remark..
Well after much GOOGLING and wondering why there is so little info about it, and my HAYNES manual just refers me to bring it to a garage for anything ABS-related, it seems that Autozone is forbidden from giving ABS/AIRBAG codes out, the Govt and MFG'ers discourage it. SO the same OBDII port is used as for normal engine fault codes, but a special reader is used that reveal the ABS faults. Consider myself educated. I will probably wait until I am forced to bring to the garage for something else, and have them deal with it if I don't upgrade vehicles after the winter is done, look like at least $150 for an ABS code reader...
jhg_12
1978 - 1996 Big Bronco
Apr 22, 2013 03:55 AM
_Me2_
Mar 9, 2013 10:11 PM
speedyejl
Apr 21, 2010 02:38 PM
motorhead5673
1997 - 2003 F150
Dec 8, 2009 07:32 PM
ripcurl94
Feb 6, 2007 09:03 PM
