I'm going to be installing a 40 series on my ex, I'm just curious on how big the inlet and outlet size is because it is three inches on the muffler. Will this work or do I need to order a larger or smaller size, and if anyone has had experience with these, did yours come with clamps or did you have to buy them separate
It will be 3" in and 3" out and if I remember correctly it didn't come with the clamps.
Magnaflow..... Flow"masters" are for rednecks in cheveys that like to loose teeth and kiss their sister (not that there is anything wrong with that (yes there is), no offense if you're into that).
All brothers in my family and I HATE country music (with the exception of the actual real performers like Cash, Bob Wills and Hank Williams). Also I finished high school and have all of my teeth and think gun rights mean you should be allowed to have a gun, not that you should have a gun
So you think I should go with a magna? Well could you help me out with the sizes, if the ex has 3 inch inlet & outlet what size should I get on the muffler, thanks
Go with a 3 inch inlet for sure but a 3 or 4 outlet depending on what kind of tip you want to go with. Most shops don't stock/bend 4 inch either so keep that in mind as well. It's easiest to just go 3 in and 3 out for simplicity.
