Beadlock Wheels are there any?
Old Mar 20, 2015 | 11:17 PM
Johnny Be Cool's Avatar
Johnny Be Cool
I'd like to get a set of black beadlock wheels for my 74 f250 4x4.
I see they have some for Hummers but since there are steel they can't be down to fit over the hubs as you would do a set of aluminum ones.
Where would be a good place to get a used set and what vehicles would they come off of to fit mine.
Old Mar 20, 2015 | 11:46 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes.......http://www.alliedwheel.com/wheels.ph...tion+Beadlocks To locate a used set with tires ck out "racing junk" or some other rock crawling dedicated site, that has a classified section.
Mil take off 12 or 24 bolt HUMVEE with magnesium or the rubber run flat/beadlocks will fit a rear D60. FYI they are 8 on 6 1/2 bolt pattern and 16.5 for tires sizes. 36 or 37's come on them. There are 7" deep set or off set, the rim will hit the tie rod ends and alot more if you just try to bolt them on the front end of a D44 or D60.
To use H1 rims on a Ford without recentering them. If you want to use them in a stock form, then you need a 76" wms. Stock single wheel rears are in the 67" range. So basically if you have a 60 front you need the dual wheel hubs. If you’ve got a 44 then get the front drw spacers from a 88-up chevy or 94-up dodge. For the rear get a dual wheel rearend from a pickup. Can’t be from a cab and chassis truck. Those have a 72" wms. Then you can get a 2" spacer. Another option is if you can find a drw 14b or d70 hd from a chevy you can swap the drw hubs for the srw hubs and you’d be set. Have to figure out brakes but with a disc swap it’s not hard.
Get a set for cheap and get them recentered to run them with out a lot of axle end modifying. So some say....Google has other alternatives for brands, and there is even a few that are DOT approved. Just make sure you get some that are DOT approved, some insp places will not let them pass if they do not have the bla bla wording.
http://www.aev-conversions.com/pdf/B...onceptions.pdf
LiftLaws.com - Are Beadlocks Street Legal?
Military Double Bead Lock H1 Hummer 12 Bolt Wheel
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
OMF Performance Products | Beadlocked Wheels
Off-Road Racing Beadlock Wheels - Starting at $129.95
TRBEADLOCKS.COM
Spyderlock beadlock home
Anza Beadlock - D116 - Fuel Off-Road Wheels
Hutchinson Industries - Beadlock
Coyote Enterprises Coyote Beadlock FAQs
This ought to get you some answers.
Old Mar 21, 2015 | 06:29 AM
gatorfor88's Avatar
gatorfor88
Unless you are airing the tires down below about 12 psi and wheeling hard there is no need for beadlocks. If you want the "cool" factor there are fake beadlocks available from almost any good wheel manufacturer.
Old Mar 21, 2015 | 07:21 AM
HIO Silver's Avatar
HIO Silver
Fyi... few true beadlock wheels are street-legal. Do your research.
Old Mar 21, 2015 | 10:05 AM
Johnny Be Cool
I've been scanning the web for a set of used wheels and saw a few posted beadlocks. I really like the look, but after reading HIO Silver's tech information, I'd have to say it gave me a scare and it's not a chance I want to take.
Thank you HIO Silver for all of that detailed information and the time it took to get it together.
I'm gonna pass on those wheels (Another good reason to be a member here, reliable information!!!)
RMCOTNER
1947 and Older Ford Trucks
Feb 21, 2018 08:52 AM
Thompson93
Apr 3, 2017 06:56 PM
kwiknova
Nov 30, 2016 07:14 PM
Johnny Be Cool
Feb 6, 2015 10:25 PM
kermmydog
May 29, 2007 11:31 PM
