What should I do next
Old Mar 20, 2015 | 04:24 AM
jefrow03's Avatar
jefrow03
Question What should I do next
ok I'm stumped 92 f 250 4.9 i6 4x2 mt. Not starting. Spark is good new plugs,wires,distributor,rotor. Just replaced pcm old one fried, plugged new one in no start,hit it with starting fluid and it ran for a few seconds so figures fuel problem. New fuel pump in, pressure tested at 56 psi. Relay is good, inertia switch good , why won't it start? Any ideas on what to do next?
Old Mar 20, 2015 | 07:48 AM
AbandonedBronco's Avatar
AbandonedBronco
Have you replaced the fuel filter?
Old Mar 20, 2015 | 08:12 AM
250FOREVER's Avatar
250FOREVER
My daughter had a car ( another American make ) that the security system that nobody knew it had disabled the injectors . Your scenario sound similar (" pressure tested at 56 psi. , Spark is good , hit it with starting fluid and it ran for a few seconds").With all the things you have mentioned doing is there a way you could have set one off ?
Old Mar 20, 2015 | 06:49 PM
jefrow03's Avatar
jefrow03
As far as I know there isn't any security system, if there is I don't know about it but I don't see how it would have one no power locks or anything
Old Mar 20, 2015 | 06:52 PM
jefrow03's Avatar
jefrow03
No I haven't, how would that help if I'm getting correct pressure at valve?
Old Mar 20, 2015 | 08:17 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Have you pulled codes? Perhaps the EEC can tell you what's amiss.
Old Mar 20, 2015 | 10:12 PM
AbandonedBronco
The flow through the filter may be enough to build pressure when none of it is being used.
As soon as it starts, it can't keep up anymore.
Just something to check.
Old Mar 20, 2015 | 11:47 PM
jefrow03's Avatar
jefrow03
Yes just pulled them, got the following, 114 air intake temp sensor out of range, 118 engine coolant sensor is/ was high or open, 522 park/neutral position or clutch pedal position circuit fail. Any insight? These are things that I don't have any knowledge on
Old Mar 21, 2015 | 04:52 AM
BaronVonAutomatc
522 is the problem, the EEC won't let the engine start unless the vehicle is in neutral or the clutch is depressed.
Old Mar 21, 2015 | 09:50 AM
jefrow03's Avatar
jefrow03
Ok well I just read that you need to have the clutch pushed in while doing KOEO test, I didn't have it push down would that cause it to give that code? How can I fix this?
Old Mar 21, 2015 | 02:39 PM
jefrow03's Avatar
jefrow03
So here's a question would the vehicle crank and not start or would it do nothing? The reason I ask is I have a push button start that goes right to the solenoid and gives the starter power it cranks just won't start
perry b
20
Sep 14, 2016 08:22 PM
joabthebugman
Sep 10, 2014 09:47 PM
bob.p
Aug 12, 2014 09:28 AM
Rothschild
Mar 7, 2009 11:12 AM
vee-eight-fords
13
Feb 3, 2004 04:41 AM
