Park Light Dimension?
Old Mar 19, 2015 | 09:14 AM
clintonvillian's Avatar
clintonvillian
I need just a rough length of the park light lens under the headlights.
Also, how do the trim pieces mount? Do they screw through the mount into the gravel pan? Or are they attached to the mount alone?
Old Mar 20, 2015 | 10:16 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
The lens is 5" wide by 2 3/4" up and down., The glass is curved on the bottom so both sides measure less then the center up and down. Reproduction lens available in clear or amber. The trim piece attaches with two screws directly to the bulb holder mounting bracket. The base mounting bracket is available as a reproduction. The trim pieces are available painted or polished stainless. Since the mounting bracket attaches to a painted gravel pan and the bracket is also the negative ground for the park light, you might need a separate ground wire between the bulb mounting bracket and the chassis/body.
orderthesun
15
Dec 5, 2022 11:12 AM
KJWhit
Oct 11, 2018 03:27 PM
shadetreezj12
WTB - Parts & other
Dec 22, 2015 03:20 PM
JBronco
1978 - 1996 Big Bronco
Feb 21, 2012 10:40 AM
