Bent Antenna Stud/Bracket
Old Oct 11, 2018 | 03:27 PM
KJWhit's Avatar
KJWhit
2017 Ford F 250 Super Duty. The threaded stud that the antenna mounts on is bent and the bracket holding the assembly is broken. Can't imagine how it happened unless someone intentionally bent it. Has anyone replaced this? I found a OEM item called an Antenna Base but it looks like it has be be run all the way back through the fire wall. The antenna mast was undamaged. No way to bend the stud back in to place plus the bracket below the rubber trim needs to be replaced.
puckett_jw
Mar 1, 2017 07:44 PM
onug
2015 - 2020 F150
Jun 26, 2016 11:57 AM
Rads 79
Feb 23, 2010 09:20 PM
pod4
Sep 16, 2002 11:13 AM
