Death Wobble
Old Mar 18, 2015 | 03:29 PM
dr103's Avatar
dr103
Death Wobble
I've searched & read a lot of stuff on the FTE & it seems as though anything & everything causes the death wobble.
My case is like this. 90% of my miles are pulling a gooseneck trailer with approx 25000 lbs (total weight). The wobble has happened twice & both were very severe. 107000 miles on truck with no mods on suspension. Tires have about 25% left with Michelins. It has been a while since rotation & balance on tires, but wear is very even & good. This has just started within the last month. Have not noticed anything happening with truck. Both places the wobble occurred was on some bad roads around Raleigh NC.
Any help would very appreciated.
David
Old Mar 18, 2015 | 03:37 PM
tonefordays's Avatar
tonefordays
Dual front stabilizers.......they make a world of difference.
Old Mar 18, 2015 | 03:49 PM
mustang_309's Avatar
mustang_309
David
Check all of your steering and suspension components for wear ie: tie-rod ends, ball joints, drag link and steering gear. The most likely component to cause the death wobble is worn track-bar bushing and/or ball joint as this keeps the axle centered under the frame.
Old Mar 18, 2015 | 05:59 PM
87crewdually's Avatar
87crewdually
Death wobble is an indication something is wore out and has excessive play enabling the wheels to oscillate independently of the steering wheel. As said above, get your ball joints and tie rod ends checked out.
As far as adding additional steering stabilizer, that would be a band-aid and just masks the problem that already exists allowing it to worsen creating a larger risk of complete failure.
Old Apr 9, 2015 | 08:43 PM
dr103's Avatar
dr103
Death Wobble
Took it to my Ford dealer & they replaced the steering damper. They also balanced my front tires. That seems to have fixed it for now. Truck has not shook since then.
David
Old Apr 9, 2015 | 10:26 PM
Jeff Watts's Avatar
Jeff Watts
Something is still worn out. Don't roll the dice with that much weight. Find a competent front end shop, and have it gone over real good.
Old Apr 10, 2015 | 07:31 AM
mohoneywell's Avatar
mohoneywell
How is the trailer load balanced? That is some weight, and even a 5'er/ GN with an unbalanced load can affect the steering.
Also I agree that the dealership put a bandaid on it and you most likely still have an issue.
Old Apr 11, 2015 | 03:35 AM
One Cylinder's Avatar
One Cylinder
My '03 2wd with halfway worn michelins would get the DW after hitting minor bumps. Replaced front shocks, checked front end components; no help. Replaced tires with cheaper tires no more DW.
My '05 4wd never has DW.
From what I've read, the DW is a result of improper "Caster". SDs do not have caster adjustment. For example, when you get the shopping cart with the wobbling wheel. The wheel assembly is bent back enough not allowing the wheel to track properly but causing a woble.
I have seen a kit online to add caster adjustment to SDs. I believe this mod will solve the DW problem.
Old Apr 11, 2015 | 03:54 PM
rhjj's Avatar
rhjj
My issue with DW was cured with new trackbar bushings. 2005 F350 4X4. Steering stabilizers are a band aid, solve the problem.
Old Apr 11, 2015 | 07:42 PM
jswartz84's Avatar
jswartz84
From what I understand about 95% of the time, DW is caused by a Trac bar issue.
roboto
18
Jul 3, 2017 07:52 PM
awillo0406
Aug 7, 2014 04:30 PM
bulldog389
Jun 25, 2013 08:28 PM
asmyth18
Apr 4, 2012 09:19 AM
gruveb
1978 - 1996 Big Bronco
Nov 12, 2002 09:45 AM
