Heater/Blower Box Delete
Old 03-18-2015, 05:24 AM
Vegasw0lf's Avatar
Vegasw0lf
Vegasw0lf is offline
In my 77 F150 I currently have the heater bypassed, and the AC deleted from the 460 swap.
That huge **** blower box under the hood is a huge, ugly PITA.
Anyone ever remove it permanently? Have any pics?
I figure I don't need the blower, since I got windows.
Old 03-19-2015, 01:59 PM
norts1138's Avatar
norts1138
norts1138 is offline
[QUOTE=Vegasw0lf;15187317]In my 77 F150 I currently have the heater bypassed, and the AC deleted from the 460 swap.
I figure I don't need the blower, since I got windows. [/QUOTE
I did the same to my 74 f250.once you take out the black box the fan for you heater will not work because it is inside the box and you will have a hole in the fire wall.
you will need to unhook the two hose from the a.c. compressor.next inside the calender the dash on the passenger side you will need to take off the plastic cover part of the heater.
Now that you have the heater cover remove you should simply take out the a.c. radiator looking device followed by the heater core.now that all the internal parts are removed the rest is just removet the bolts around that the block box is attached to the fire wall,some are removed from under the hood and some from inside of the cab.
The one that is in the bottom corner near passenger side I just pounded out from the inside of the cab since its a tight fit to get a tool on it.the bolts are held in with a clip.
Removal after all of that is just a matter of wiggling it out.
Now remember you will now have a hole in the firewall where the a.c. unit once was.
To fill the hole I traced a piece of sheet metal and made it a hair too big and bent the edges and pounded it in the hole.next sealed it up and called it good
Old 03-19-2015, 02:17 PM
bkaul's Avatar
bkaul
bkaul is offline
You could remove it, patch the hole with sheetmetal, then replace it with the heater box out of a non-AC truck so you have heat/defrost when needed.
The following users liked this post:
Old 03-19-2015, 06:28 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,358 Likes on 2,496 Posts
X2 on take out the giant box and patch the hole with a piece of metal or.....and yes a none a/c equipped truck blower/interior box set up will be much appreciated come foggy window time like on rainy days or when there is a chill in the air. A jy should have the different interior box and blower set up and different control panel.
Old 03-20-2015, 01:30 PM
Zemmeron's Avatar
Zemmeron
Zemmeron is offline
I'm currently in the same boat with the heater box delete project. I went the route of ordering a vintage air gen 2 kit heater box with defrost. Will post on here how everything went together once completed.
Old 03-21-2015, 11:07 AM
Vegasw0lf's Avatar
Vegasw0lf
sweet, cant wait
Old 03-21-2015, 11:37 AM
84espy's Avatar
84espy
84espy is offline
I did this and it all works good. Good luck with your project
https://www.ford-trucks.com/forums/1...ng-my-way.html
norts1138
02-26-2014 07:43 PM
ejohns06
1978 - 1996 Big Bronco
11-18-2012 10:27 PM
kevin316
02-06-2011 08:16 AM
frosty64
04-11-2005 09:45 PM
ivanribic
06-12-2004 07:20 AM
Quick Reply: Heater/Blower Box Delete
