fuel pedal problems
Old Mar 17, 2015 | 11:39 PM
68bumpside's Avatar
68bumpside
fuel pedal problems
ok so a year ago my factory fuel pedal went south, went to parts store and got new one. now every 2 months it gets to going out, surging at highway speeds, if i let off the fuel the check engine light comes on and i tap the pedal 4 or 5 times then it works again, replaced 3x in the past year.
are all the aftermarket pedals junk or is their something else going on, truck is a 2002 F250 7.3psd auto with 415,000 miles
Old Mar 18, 2015 | 06:32 AM
whitetmw's Avatar
whitetmw
If the IVS and the TPS become out of synchronization a code will set and you loose acceleration.
Since you've replaced so many. I would suspect the wiring or connection. Try some Elec. Contact Cleaner on the Plugs before replacing again.
If you have a Scan Tool, you can compare the two PID's and see which one is (IVS/TPS) suspect for further troubleshooting.
You can monitor each switch by using a DVOM to compare the movement / resistance using (Ω).
It's also possible the connection at the PCM is dirty/corroded and requires cleaning.
Old Mar 18, 2015 | 07:37 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Mine was doing that and I cleaned the tps and connectors with electrical cleaner and it has been perfect since.
Old Mar 19, 2015 | 05:10 AM
68bumpside's Avatar
68bumpside
thanks i'll try that and my pedal dont have 2 sensors just the one
Old Mar 19, 2015 | 08:33 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Well, I meant the male and female connectors on the tps, just the one sensor haha.
Old Mar 19, 2015 | 09:30 PM
whitetmw's Avatar
whitetmw
You have the 9-Pin Connector, but still two Sensors in the pedal. Same set up, just one plug + APCM 4 wire accessory wire (which were separate in early models).
<table width="100%" align="center" class="tborder" style="border-top-width: 0px;" border="0" cellspacing="1" cellpadding="6" abp="1336"><tbody abp="1337"><tr title="Post 15187381" valign="top" abp="1355"><td class="alt1" abp="1357">Still, If the IVS and the TPS become out of synchronization a code will set and you loose acceleration. You just have one plug in lieu of two separate plugs (5 Wires vs 2/3).
Again, if you have a Scan Tool, you can compare the two PID's and see if it is in fact the pedal.
You can monitor each switch by using a DVOM to compare the movement / resistance using (Ω) in the appropriate pins on the pedal..
</td></tr><tr abp="1366"><td class="thead" colspan="2" abp="1367"></td></tr></tbody></table>
Old Mar 21, 2015 | 10:46 PM
68bumpside's Avatar
68bumpside
what do i do about it if it is out of sinc and how does it get out of sinc
Engalwood
Sep 27, 2012 11:28 AM
putz54143
Dec 2, 2008 07:58 PM
RÖENTGEEP
Sep 19, 2008 08:26 PM
kawa
Apr 5, 2008 09:12 PM
