A Ford Tractor Could Do It!
Old Mar 18, 2015 | 11:41 AM
  #31
daverd4's Avatar
daverd4
Trailering
You mean like this. Built this in a few hours and it works pretty good.
Old Mar 18, 2015 | 12:13 PM
  #32
Jafo56's Avatar
Jafo56
That my boy is a great invention for moving our precious junk all over the yard!!! N
Old Mar 18, 2015 | 12:17 PM
  #33
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Well now that's cool.
Old Mar 18, 2015 | 12:31 PM
  #34
Sportster.Mark's Avatar
Sportster.Mark
Okay, I will start looking for a tractor!
Right now, I use the '86 F250 4X4
Old Mar 18, 2015 | 07:07 PM
  #35
bigwin56f100's Avatar
bigwin56f100
Daverd that lifting point needs to swivel , I bet that's a bear to go anyways but straight
Old Mar 18, 2015 | 07:35 PM
  #36
daverd4's Avatar
daverd4
Trailering
It has a swivel under that channel iron that goes under the axle. There is a pin welded to the channel and goes through a pipe in the box beam no way you could turn with out it.
Old Mar 18, 2015 | 09:53 PM
  #37
Muppy1840's Avatar
Muppy1840
That's pretty ingenious . I need to make something like that for my skidsteer on the end of forks.
Old Mar 18, 2015 | 09:59 PM
  #38
abe's Avatar
abe
Look what I found on the way home from school today!
This car dealer usually has some nice classics for sale inside. Today I saw this Ford tractor sitting out side as I drove by so I had to stop and get a picture. I do not know what year it is. It said Ford 4000 on the side. It was a fairly well done restoration.
Old Mar 18, 2015 | 10:03 PM
  #39
willowbilly3's Avatar
willowbilly3
3020 JD with loader, JD 90 skidsteer or winch it on the trailer.
Old Mar 18, 2015 | 10:23 PM
  #40
jmadsen's Avatar
jmadsen
Thats nice! You should buy it before someone else does.
Old Mar 19, 2015 | 09:56 AM
  #41
52 Merc's Avatar
52 Merc
That's an early 60's tractor. TractorData.com Ford 4000 tractor information Nicely done. Photoshop all the newfangled machinery from the background and you could have a period correct picture.
Old Mar 19, 2015 | 12:39 PM
  #42
OldGrayMare's Avatar
OldGrayMare
I use my 12hp garden tractor, it will pull my 5,000 pound Bronco on level ground as long as it's dry out.
Old Mar 20, 2015 | 12:57 PM
  #43
tractormanbill's Avatar
tractormanbill
tractorman
Watch out for the MF gas tractors as about 90% of them have cracked blocks.
If it has new engine oil or milky oil run from it fast as it won't be a headgasket!
TractormanBill
Old Mar 20, 2015 | 02:51 PM
  #44
Fomoko1's Avatar
Fomoko1
TractormanBill
I bought an MF 88 diesel with a Continental engine that had multiple cracks in the head and finding a good used one was almost impossible so I had it cold welded.
Old Mar 20, 2015 | 02:54 PM
  #45
tractormanbill
tractorman
I'm talking mostly about the TO 20-35 smaller continental engines.
TractormanBill
