Hey Rusty those switches or upfitter switches are functional right? I've also seen some 450/550/650 lower dash units that come with those installed? You know where to get them? Really thank you and danny, and mho for the help. Ended up ordering new harness from a local company here. Thanks again bud..
Sean
'04 late, T6 full synthetic, my EGR upgrade, 35" Coopers, Hi Idle Mod., next on list is remote oil and coolant resvrs.,then tranny flush/ fill with new filters.
Yes sir, fully functional. The switches turn power on and off at the terminated wires under the dash. It's a little more complicated than just the switches tho, the system includes relays and two of them are rated at 30 amps. Here is a link from the Tech folder with more details. https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf . The parts should be available from your favorite supplier that has access to Ford stuff but a salvage yard may be a better option.
Thanks Rusty I'll check it all out thank you. I'm tracking down parts now to put it all together. I'm going to order a lower dash kit from MK, and start wiring!! Woohooah. A lot of elbow grease to go, but I'll get this ol girl back to her former glory. Thanks for all your help.
