Aussie head 400 pistion source
Old Mar 16, 2015 | 11:54 AM
buckin69bronco's Avatar
buckin69bronco
Was just looking around at Tim's web site and it now says that the aussiehead 400 pistons will be discontinued.
I'd just go ahead and order a set now for my build except that I won't beable to determine final bore size for a few months or more.
Does anyone have a backup source for these types of pistons. Yes custompistons would be an option but wow that's a lot of $$$
Old Mar 19, 2015 | 02:15 AM
BuzzLOL's Avatar
BuzzLOL
. Tim can prolly suggest another of his pistons that will work... there's no other source... except using 351C pistons and rebushing the connecting rods to correct pin size...
Old Mar 19, 2015 | 11:50 AM
buckin69bronco
Talked to Tim and his suggestion for an alternative was custom pistons. He had one set of 020 over pistons for the aussie heads left so I bought them and now have to hope that my block can be cleaned up at 020 over or I'll have to hunt down a block that can be.
Lots of 351c pistons would fit but with the 60cc-ish chamber size of the aussie heads there is no sorce for a 30+cc dish 351c piston to maintain a reasonable compression ratio.
I wouldn't go through all this trouble except for the fact that I already have fully reconditioned aussie head.
Old Mar 19, 2015 | 11:53 AM
TMI's Avatar
TMI
Aussie pistons are officially gone.
Jake snagged the last set.
I have looked at many off the shelf pistons, none of the pistons currently being made have a dish large enough for use in a 400 with the 302 Cleveland heads.
I thought about installing pin bushings offset to obtain our "Zero" deck height.
If you take the biggest dish (13cc) bush the rod, it would sit about .050" down in the hole, and still yield 10:1 C/R. If your going to leave the piston down in the hole that far, then why use the Aussie heads then.
A zero deck height pistons requires 30cc dish.
So why don't we make them anymore, the last set that Jake bought was manufactured April 2011. That is way to long for inventory to be sitting on the shelf.
Old Mar 19, 2015 | 12:24 PM
buckin69bronco
Thanks for the help and the explanations Tim, I'll be ordering more parts from you as soon as I get my block in order or find one that will be good at 020.
1978Crew
13
Oct 17, 2010 07:30 AM
71dusterdan
Dec 28, 2006 01:55 AM
beensack
May 30, 2006 10:02 AM
TMI
16
Apr 17, 2006 04:35 AM
danlee
33
Sep 25, 2003 06:59 PM
