Hard start error code P22291
Old Mar 16, 2015 | 12:40 AM
Carlos Span's Avatar
Carlos Span
My truck start fine cold start. Hard start after it's been running. I received P2291 code when trying to start after driving around the block. I have already done a HPOP. Also rebuilt infectors. When trying to start the IPR was slowly climbing and truck hard four long cranks. When the IPR finally got up to 300 PSI then truck started. Can it be just my IPR? Or something else could be going on. Could my oil cooler cause this problem also. I know I need to replace it. Thanks for the help.
Old Mar 16, 2015 | 03:22 AM
Maxium4x4's Avatar
Maxium4x4
It takes 500 psi to start the truck....
Old Mar 16, 2015 | 07:53 AM
dannyboy950's Avatar
dannyboy950
Either you have a biased ICP sensor or the most unuseual 6.0 I have ever seen or heard of to crank and run at 300 psi.
Old Mar 17, 2015 | 04:50 PM
snorindad's Avatar
snorindad
no your oil cooler is not a cause. the coolant side of your cooler is clogged. unless it is ruptured and you have oil in your coolant than maybe.
Old Mar 18, 2015 | 09:15 AM
Carlos Span
Any ideas on how to test?
Old Mar 18, 2015 | 09:39 AM
npccpartsman's Avatar
npccpartsman
Pull the IPR and check the screen for trash.
Loftatsea
Jul 31, 2015 01:29 PM
softpickle
Jan 23, 2015 07:45 PM
Alight72
Oct 29, 2014 07:20 PM
knsahara
Oct 19, 2011 05:30 PM
SHAWN056.0
Sep 13, 2010 09:33 PM
