i went to rebuild the front end of my truck today and the axle pivot bushings in the kit are WAY to small i think mine is the HD front end where it has the 12"x2.5" brake shoes does anyone know the part number for the hd bushings the best i can tell mine mesure 2"od on the small side of the bushing
Did you get the OEM style rubber bushing or urethane bushings? With urethane bushings you have to reuse the original outer metal shells off your old bushings.
urethane bushings and the outer metal is still in the I beam that is just the rubber in the pic and the bushing in the metal outer jacket the bushing just flops around
