I have a 1972 F100 with a 351 windsor and a c4 tranny. This is the way I bought it about a year ago. I know the 351 wasn't available and came with either a 360 or 390. Well my engine doesn't get to warm and the gauge needle barely moves. It feels like a cold engine when driving in the city even after a 30 minute drive. I have put one of those temp guns and it barely will reach 170.
The big radiator is still being used. Is it possible that I need a smaller radiator to fit the 351?
Also to add, I have a rebuilt 351, rebuilt carb, Duraspark timing, and everything is tuned good with timing and all. The truck runs good but I feel like it is a little sluggish from the start and believe it is running to cold. Oh yeah and I do have a thermostat.
Thanks for suggestions. I know the 351 windsor is being used out there. What radiator are you using?
I know the 351W wasn't available and it came with either a 240 or 300 I-6;302, 360 or 390.
Well my engine doesn't get too warm and the gauge needle barely moves. It feels like a cold engine when driving in the city even after a 30 minute drive. I have put one of those temp guns and it barely will reach 170.
1967/72 F100/350: TWO different radiator supports.
If the "big" radiator is the Super Cooler (26 1/4" wide x 24 1/4" high), it uses a different radiator support than the standard, xtra cooling and A/C radiators (26 1/4" wide x 19 1/4" high).
So...if you install a non Super Cooling radiator, you will have to modify its mounting brackets, as the Super Cooling radiator support has a larger opening radius.
OP says he has a t-stat, but did not say what temp it is. IMO if the t-stat is the correct temp, he should not be running too cool.
IF the rad really is too large, which again I think is almost impossible within the parameters given, OP could use a smaller fan, or restrict air intake with sheet metal or plastic, or try cardboard for a temporary test.
Also, if this is a carb motor the carb needs a little heat usually. Exhaust through the intake or hot water in the spacer under the carb are the standard methods iirc.
If the Thermostat is working it should come up to temp. If the radiator is to big the temp would drop back after the thermostat opens. It sounds like it might by a fail-safe thermostat that is bad. I have seen new ones bad right out of the box, and when they fail they are in the open position, and it will not heat up.
I was having a similar issue on my 99 PSD. The engine ran too cool. It would take forever to warm up, and as soon as I stopped, it would fall down again. The thermostat was there, and it was closed, but who knows when it was opening.
I replaced it with a new 195 unit and problem solved. Warms up faster, holds temperature, doesn't fluctuate anymore.
