1999 Ford Explorer 4x4 issue with reverse
Old Mar 14, 2015 | 10:54 AM
Tim Curbow's Avatar
Tim Curbow
Hi. I am having quite an issue and thought I would post here to see if anyone might have any helpful hints for me to try. I recently had an issue with my transfer case that caused me to have to replace it with a rebuilt one. I did so and am now having a different issue. I have a **** on my dash that shows Auto, 4 High, and 4 Low. Whenever I shift that **** over to 4 High from Auto the light changes and I hear a click sound. When I shift the **** from 4 High to 4 Low I get nothing. So, I took off the transfer case motor and switched things over by hand. When I shift the transfer case (manually by hand) over to LOW setting on the transfer case; it seems to run ok as if it is in 4 low, BUT, when I shift the transfer case (manually by hand) over to HIGH setting I can shift into every gear but seemingly have no reverse. Reverse seems to make a whirring grinding sound. Any help or ideas would be greatly appreciated at this point. Feel free to ask questions if you need more info.
Old Mar 14, 2015 | 08:38 PM
aquanaut20's Avatar
aquanaut20
The transfer case has no connection with the direction of travel, a whirring noise is usually connected to a broken/stripped sprag in the transmission...
... Philip
Old Mar 15, 2015 | 05:07 PM
Tim Curbow's Avatar
Tim Curbow
Thanks for the input. I do have a question though. Wouldn't the sound be happening in both auto and 4 low instead of just happening in auto?
pthfndr80
1997 - 2003 F150
Mar 31, 2015 08:07 PM
turbo diesel fan
Jul 20, 2011 11:04 PM
griswold
Dec 9, 2004 07:41 AM
theFabulousmisterG
Sep 2, 2004 08:56 PM
