Diesel tank selector
Old Jul 24, 2003 | 10:59 AM
Kikko's Avatar
Kikko
I have an '86 E350 Diesel I recently aquired. I filled both tanks and gage reads full. The switch was on the front tank and I drove forever, thinking hey, I'm getting great fuel mileage. Then I decided to switch to the rear tank which read 1/4 tank. So my thought is that the front tank is not feeding the diesel. Why?
Do I need a new valve switch?? Is there a test with a meter I can perform? Do I need another switch? BTW this switch is located drivers side just before the front tank. Thanks
Old Jul 24, 2003 | 11:02 AM
GR8Diesel's Avatar
GR8Diesel
Could be a fuse or bad fuel solenoid. Don't have experience with your model, but suspect that the switch is not the first place I'd look.
Old Jul 24, 2003 | 02:08 PM
Kikko's Avatar
Kikko
GR8 thanks. I just drove to the store and again the rear tank is reading full, decided to switch tanks and lo and behold the front tank shows 3/4 full. I guess the wires are crossed because it appears that when the switch is positioned to the rear, it's actually feeding off the front tank and visa versa. .
I don't know which wires to switch but just as long as I can use both tanks, I'm happy .
Old Jul 24, 2003 | 02:16 PM
GR8Diesel's Avatar
GR8Diesel
A little labelmaker may help on that - glad to hear it is a manageable problem :-)
Old Jul 24, 2003 | 02:20 PM
Kikko's Avatar
Kikko
Label won't help because I won't know how much fuel is left in the tank unless I switch back and forth..but you're right, it's manageable.
Old Jul 24, 2003 | 02:31 PM
GR8Diesel's Avatar
GR8Diesel
So your fuel gauge and tank selector wires are out of sync.
I would think that was an easy fix. Perhaps someone on this forum could tell you where those wires are, one the back of the switch or a relay somewhere.... Then you could reverse them and all would be good :-)
Old Jul 25, 2003 | 01:55 PM
Kikko's Avatar
Kikko
Can anybody tell me whcih and where the wires are to switch? Thanks
Mbsmr
Nov 27, 2012 08:55 AM
Matrixkingkong
Nov 7, 2012 09:57 PM
boots6868
Feb 28, 2010 01:49 PM
DonnieG
13
Jan 10, 2009 09:52 PM
neumanc
Sep 19, 2003 12:43 PM
