1978 - 1996 Big Bronco
1996 5.0 "clunk"
Old Mar 13, 2015 | 08:29 PM
freefisherman's Avatar
freefisherman
1996 5.0 "clunk"
Taking off from a complete stop I feel one, sometimes 2 big "clunks" and its quite hard to locate, anyone have ideas as to what it is and how to fix it? I ran it by a few people and they didn't seem to know.
Old Mar 13, 2015 | 08:55 PM
ZombieSlayer's Avatar
ZombieSlayer
Does it happen when stopping as well? I have the same issue and the most likely culprits (in no particular order) are:
Motor mount(s)
Transmission mount
Spline gear
I have a couple of different guys look into it and just from a cursory inspection and drive it hasn't been nailed down specifically yet. Of course since everything else is original on my truck, I'm sure all of mounts and bushings need replacing
Old Mar 13, 2015 | 09:04 PM
Deadsquiggles's Avatar
Deadsquiggles
I had the same problem with mine when I first bought it and it ended up being an axle shaft.
Old Mar 13, 2015 | 09:12 PM
freefisherman
I bought mine from a lady that bought it in 96 off the lot, they did regular maintenance on iit but they let a few things go that I gotta take care of lol, thanks for the input
Old Mar 14, 2015 | 01:43 PM
Toyman's Avatar
Toyman
Check radius arm bushings also, I have had them clunk when bad. Could also be a sway bar link or loose shock. So many things can make noise. Need to try and pin point where the noise is on the vehicle, front/rear/middle....
Old Mar 16, 2015 | 08:49 PM
Pickupmanx2's Avatar
Pickupmanx2
Maybe similar, maybe not, but on my 02 F350 CC/4x4 it would clunk, turns out it was the splines on the drive-shaft, pulled apart, cleaned, lubed, new boot,,, no more clunk.
Old Mar 21, 2015 | 10:03 AM
shaker666's Avatar
shaker666
+1 on the driveshaft slip yoke splines.
Old Mar 23, 2015 | 10:18 PM
freefisherman
just greased my slip yoke, hasn't clunked all day so I believe problem is solved
Bright
20
Aug 26, 2015 02:45 PM
F-erOnlyRunsDwnhill
Jul 21, 2014 02:07 PM
austin2466
Mar 31, 2009 10:07 PM
tankglh21
Aug 18, 2005 02:15 AM
TexasGuy001
Jun 15, 2005 05:35 AM
