Engine swap thought
My 360 has a tick that sounds like a lifter and with it running and me under it sounds like the it's at oil pan level. I know tracing engine noises can be impossible sometimes.
To finally get to my point. With 360's considered big blocks are motor mounts the same as a 460? My thoughts of not considering a small block, 400 or 351, is the weight of my truck, mounts would need to be changed I know, I just don't want to be underpowered by going small block.
It's not a race truck nor will it be it's a cruiser, I just want to be able to shut up those little tuners cars that pull up sounding like a pissed off june bug.
Kind of more of an opinion thread I guess.
You can be under or over powered with any sized engine, so don't get hung up on SB/BB.
Since you have an FE motor, the "easiest" way to more power is to stay with the FE. Aftermarket cranks can take you out to 445 with the 360 block and a .030 overbore.
A 460 swap is popular, possibly cheaper, but will require (probably) mounts and (definitly) a different bell or automatic transmission. As with any engine series change, a number of other "little things" come into play as well like exhaust, cooling, fuel delivery etc.
Check out the FE forums. There are countless 360/390 build threads.
Well that explains a lot.
Rasputin53
The 360 was built to be a low RPM torque engine, designed to pull heavy loads at a blistering pace of about 45-55 MPH.
It doesn't really matter what engine you have under the hood. If your rear end gearing is 3.25-4.11, the "tuners" are going to have something you do not --an overdrive transmission. You're terminal velocity is going to be reached in a very short distance, theirs isn't.
There are no overdrive transmissions that bolt directly to an FE block (not without adaptive means), even with overdrive, the 360 FE is designed for low RPMs.
The 351W is physically a small engine compared to a 360 but, it's only 9 cubic inches smaller than an FE 360.
There's a vast array of speed parts as well as factory production performance parts available for the 351W. Aluminum heads, intake and water pump will also make the 351W much lighter than an FE 360. --this translates to better steering and handling of the truck, since there would be less weight hanging over the front wheels.
Unlike the FE 360, there are numerous choices in overdrive transmissions (standard & manual) that will bolt directly to the 351W block, without the necessity of expensive adapters.
Depending on how much money you wanted to spend, it's possible (with the right factory performance siamese bore 351W block) to stroke a 351W to 454 cubic inches -- almost 100 cubic inches bigger than what you currently have (94 cubic inches bigger than a 360). --this would be expensive but, it is possible.
Without this expensive factory block, common 351W engines can be stroked to 393, 408, 410, 416 or 427 cubic inches.
Even if the regular 351W was not stroked, it has a higher RPM range capability than the 360 and it can be made into a stout performer with a few good engine parts, good rear end gearing and an overdrive transmission.
It's all relative but a $150 shortened input shaft for a TKO is better than a $650 QuickTime bellhousing for the FE. I don't consider that an expensive adaptation. However, obtaining a TKO transmission itself is a different matter.
Just know that a short-shaft TKO is a pure bolt-on to a bone stock FE bellhousing. Been there, done that.
Then you start kind of thinking you should of went with a SB. 302 that you'll get more bang for your buck gas wise.
And many places now days don't have the higher octane gas as it is getting harder to get if your engine is pumped way up where as having to use the higher octane ratings.. Ouch in the wallet
Then E-85 seems to be sweeping the whole country now days no good for these good classics motors. Even E-10carp in these old motors is still no good in them.
But yet some guys put in the cheapest gas as that all they can afford and thinking if runs it's okay.
Then they setup the timing max advance then wonder why it pings or the engine won't shut off when they turn the ign key off.
Just a few these to things about when building a engine..
Orich
Low buck transmission + expensive adapter;
Or,
Low buck adapter + expensive transmission.
I chose the latter because a cheap transmission isn't cheap is it needs to be rebuilt. With a higher cost typically comes mechanical certainty. You make the call.
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Thanks for all the input/advice/suggestions. I know the 360 is a stump puller I just want more power around town when I feel like showing off with my old beater truck. Tuners...ah tuners...don't want to race them just shut their pipes up at the 60' mark. I’ve sort of been following Rasputin53
thread it’s what gave me the idea of what’s next for my engine.
Right now my truck isn’t my daily driver so mpg isn’t a huge concern, soon one of my daughters will be driving it and she is a lot smarter than I am with unnecessary driving. I think my old 460 was at about 8mpg.I did get 12 once, dropped in cold plugs, while I was driving around our beautiful country for a year checking out the unusual and rarely seen towns along the way.
Anyway, I do appreciate the input that’s what makes this forum the best I’ve been on.
It’s a good mix of respect and condescending information.
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Last time I checked, a 360 will turn 5,000 RPM's no problem. Retarded cam timing (which stock 360's have for emission purposes) actually moves the torque curve higher in the RPM range.
So just to be a "counter point" to a small degree, I will agree with you on this one and add it appears Ford made the 360 in order to save production costs by using the same block and bore for both 360 and 390, while using existing pistons from 390 car engines and the crank and rods from the 352. This eliminated the 4.00 bore block and the 352 piston. As a bonus, it had low compression like they wanted.
Both the Clark 264VO and 280VO will bolt right behind an FE with the right bell housing.
As for those transmissions, they are as common as hen's teeth, and in good condition, as common as hen's dentures. OP can abandon all hope of "cruiser" status, and count on the daughter leasing a Kia with an automatic after she rows one of those sporty jobs for a while. You will also need a pilot busing that works and you'll be checking the clutch disc offereings to find one with the Clark input size and the truck clutch diameter.
Serving suggestion: Performer manifold with 500ish 4bbl, & decent headers. Add the transmission as per post 6. Drive it. Decide if you want to spend more. ymmv.....
My apologies, I tried to mix this up with my comments mixed in with the quoted post. I am too lazy to re-do the post. Everyone I've seen on this site will figure it out.....I'm so ashamed.
Stroke: 360 = 3.50" / 390 = 3.78."
If you want a 390, you don't have to swap it in. All that's required is to install the 390's crank, rods and pistons into your 360.
