4x4 question
Old Mar 13, 2015 | 05:28 PM
sbsimpson's Avatar
sbsimpson
4x4 question
Just bought a 2006 f150 with 5.4 triton the 4x4 seems to work then not work.. it's a manual shift for the 4x4.. the doesn't come on.. but lights up when you first start the truck.. any ideas?
Old Mar 14, 2015 | 06:38 AM
P.Bronner's Avatar
P.Bronner
There is a switch in transfer case that turns on the 4x4 light. It's probably failing. The ECU runs through a lamp function test upon start-up, so you know the bulb is good. I bet the 4WD is actually working.To test it just stop in some loose dirt or gravel, put the truck in 4 high and jump on the throttle. If only the rears spin, you have a problem. If its working, the truck will accelerate rapidly with little or no wheel spin.
9676x6
Apr 19, 2016 11:39 PM
Steve 99 150 4x4
1997 - 2003 F150
Aug 2, 2013 08:42 PM
deerdude
2004 - 2008 F150
Dec 28, 2009 12:36 PM
GucciSock
Jun 15, 2004 11:57 PM
