busted head bolt
Old Mar 13, 2015 | 01:51 PM
greentruck72's Avatar
greentruck72
busted head bolt
so my 390 has stock manifolds on it and i want to go to headers, but i currently have a bolt busted in the top section of the manifold bolts, what do you all suggest to get it out easily ( yeah i know nothing is easy about it), could i pull just the fender if i need to or do i have to pull the whole clip,
Old Mar 13, 2015 | 04:12 PM
dlburch's Avatar
dlburch
assuming you can get the remaining bolts out and get the manifold out of the way, put a larger diameter nut over the broken bolt and weld it...the heat usually breaks it free and you can just wrench it out...
Old Mar 14, 2015 | 10:00 AM
good to doo's Avatar
good to doo
I just went through this on my 79 f350 4x4. I pulled the clip, then the steering shaft, then I unbolted the mc and layed it down on the frame rails. Then I got in with my die grinder. It was a major pita. Hope that helps.
Old Mar 16, 2015 | 12:08 PM
greentruck72
think i could just drill it and tap it?, and i may be able to wax it out but, i dunno, im gonna go look at it here in a min and see what i can do?
Old Mar 16, 2015 | 03:37 PM
4x4slik's Avatar
4x4slik
Just went through this a few weeks ago. All the top bolts broke off. I tried every tool I could get my hands on, and every trick i could find online except welding the nut on. Nothing worked. We ended up drilling and tapping new threads. This too was a pain. It was on the passenger side, I pulled the fender, but mainly because I had just filled the radiator for the second time in 2 weeks and didn't want to drain it again. We had to use a right angle adapter for the drill. A couple of the holes were off center, but close enough to work. It was a great experience for my son. Now maybe he will buckle down and get better grades and be able to pay people to work on his stuff.
Old Mar 17, 2015 | 01:13 PM
Zemmeron's Avatar
Zemmeron
heat will be your best friend removing them bolts
dyoungen
Jun 17, 2012 06:40 PM
cjben
Aug 20, 2008 09:13 AM
79highboy150
Dec 22, 2007 01:02 PM
KDH
Jan 20, 2002 03:33 PM
71f100
Nov 9, 1999 06:38 AM
