exhaust manifold bolt size
We have a 1976 F100 with a 390. The manifold gaskets are going and I figure when we pull the manifolds the bolt holes will need a tap run into the holes to clean the threads. Does anybody know what size the threads are? 3/8, 1/2 13????
Heat the exhaust portion of the head to remove the bolt with a torch. If all else failes, get a drill motor.... I'll shut the F up now...LOL
The absolute best way to remove a broken bolt is weld a nut (or bolt) to the stub and back it out with a wrench. I just had a bolt broken off an 1/8th " inside the block and built it up with weld far enough to weld a bolt on it. It backed right out. You don't have to worry about catching the block with weld, since it won't stick to cast anyway.
I guarantee they are NOT 5/16" bolts. I'll go check, but I'm 99% sure they're 3/8" also. Like Riderman said, use grade 8 bolts. (gold in color with 6 hash marks on the head.) The anti-seize is a good idea too.
Like I said it has been a while. I do remember that sinking feeling when one of them broke off when I was changing the exhaust gaskets; and then trying to drill it out straight while the engine was still in the truck.
If you aren't using it as a daily driver, I would start spraying your favorite penetrating oil on the bolts at least a week in advance of trying to turn them.
To this day, I am leery of exhaust bolts; especially when there isn't room to get a drill between the inner fender and the head.
Robert
Robert
BrownBrutus
17
Jan 31, 2013 10:18 AM
westkane
Sep 17, 2012 09:42 PM
omni
General Automotive Discussion
May 1, 2006 12:51 PM
HawgDawg
Feb 25, 2005 05:03 PM
offroaderone
Apr 18, 2004 10:25 AM
