Vacuum lines
Old Mar 10, 2015 | 02:58 PM
Dschonauer's Avatar
Dschonauer
Vacuum lines
Request assistance in identifying where a vacuum line is supposed to attach. The line in question is right above the drivers upper control arm, it is black plastic and goes from the frame up along side the engine but the end appears broken off. Any help would be appreciated. A photo would be awesome but I realize that is asking a lot.
Old Mar 10, 2015 | 05:06 PM
pdqford's Avatar
pdqford
Vehicle?....................
Old Mar 10, 2015 | 09:17 PM
Dschonauer's Avatar
Dschonauer
Vacuum lines
Yeah, that might help, 04 Expedition 5.4, 4wd.
Old Mar 11, 2015 | 03:08 AM
Skauber's Avatar
Skauber
Probably the vacuum line for the front wheel hub for the 4x4. There's two lines going down to it, one that supplies vacuum, and one vent line which just ends in the engine bay without connecting to anything. They go down to the wheel hub via a rubber vacuum connector, together with the wire for ABS. It's not hard to spot if you turn the wheel full lock to the right if you're going to check the left one (drivers side)
Old Mar 11, 2015 | 09:53 AM
alloro's Avatar
alloro
If there is a duplicate one on the passenger side then that's the vacuum line for the front hub. If not then it might be the vent tube for the front differential.
spooktn
1983 - 2012 Ranger & B-Series
Apr 14, 2018 12:55 PM
jgdds
Jan 21, 2016 05:44 PM
TexasA&M
Sep 9, 2015 08:52 PM
4getfulbj
2004 - 2008 F150
Aug 19, 2012 06:55 AM
murph1
1997 - 2003 F150
Nov 6, 2008 10:18 AM
