Question about a sending unit
Old 03-10-2015, 08:23 AM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
For those of you who are using the 60s Mustang tank and are fuel injected....
Are you running a returnless style system?
My setup is a 2001 Ford DOHC 4.6L and a 1969 Mustang tank.
I need to get an inline fuel pump and regulator setup, just wondering what everyone else was using. Are you guys using the stock 60s mustang sending unit too?
Old 03-10-2015, 01:17 PM
walt460's Avatar
walt460
walt460 is offline
Mike, 2001 DOHC used a returnless fuel system with Fuel Pump Driver Module (FPDM) controlled by PCM. You can use that with in-tank mounted pump or you can convert to return style fuel system with an in-tank or in-line fuel pump and a pressure regulator near the feed to the fuel rail (you need return style fuel rail too).
With pump in-tank, you really need a fuel sump style tank that was designed for in-tank pumps. You can get a tank made or use several aftermarket tanks designed for this purpose, or use the 1995 Chevy van tank (22 gal) and just change the pump to the Ford/walbro high pressure pump. The are also fuel tanks made for older mustangs that are modified for EFI use, and this might be your best bet. Check with C J Pony Parts or Scott Drake or other Mustang part sources.
Old 03-10-2015, 09:58 PM
mustangmike6996
If I do a return style setup, how can I convert it to my 1969 mustang tank?
tps93ranger
Crossovers
02-22-2013 09:21 AM
James Rutley
Aerostar
06-11-2011 11:33 AM
mike L
03-18-2005 07:54 PM
RedRage
1966 - 1977 Early Broncos
04-29-2004 06:47 AM
rodbeed
01-15-2004 08:59 AM
Quick Reply: Question about a sending unit
