66 f100 ignition switch
Old Mar 9, 2015 | 07:22 PM
bphirt1's Avatar
bphirt1
Hello all. I was wondering if anyone had a picture or image of the back of the ignition switch? I just recently purchased a new switch and connector from LMC today and assume that when it comes in, it will not have the same color coded wires as original. I also purchased a new aftermarket harnesses for the truck that I am almost done installing. If anyone could tell me what goes to each terminal on the back side, that would help me a bunch.
Old Mar 9, 2015 | 08:19 PM
johnmel59's Avatar
johnmel59
Old Mar 9, 2015 | 08:28 PM
bphirt1's Avatar
bphirt1
Thank you johnmel59. This will help me a lot once the switch comes in. I have the first one which is the old style.
Old Mar 10, 2015 | 12:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As original:
C3AZ-11572-A .. Ignition Switch (Motorcraft SW-353).
1961/66 F100/1100 & Econoline // 1961/64 Galaxie // 1965/66 Mustang // 1966 Bronco.
1967: Ford replaced C3AZ-11572-A with C7UZ-11572-A for use as a "service part replacement." C7UZ switch has an extra terminal.
EDIT: FTE member banjopicker66 (see next post) has the schematic for the 1967 C7UZ switch.
Beginning in 1967 with dual master cylinders: Plastic brake warning lamp switch threads into the Brake Pressure Differential Valve.
Old Mar 10, 2015 | 01:04 PM
banjopicker66's Avatar
banjopicker66
Note that the "Brake Warning Light" does not exist on the switches prior to '67, so do not be confused when you cannot find the wire, the bulb or the socket for it.
This switch, as ND has pointed out, is the later service replacement. Although it is an exact fit, your truck has no provision for that wire.
That post is grounded out at "START" to give a witness to the brake light in the cab that it is working.
Prior to '67, vehicles did not have dual front and rear brake circuits, so there was no place to put it.
However, if you decide to upgrade to dual circuits, this is the post used to momentarily illuminate the "BRAKE" light n the cab, to show that the bulb is working.
Old Mar 10, 2015 | 04:59 PM
bphirt1's Avatar
bphirt1
Thanks for all the help. I believe that I have everything figured out except the coil wire that comes off the new fuse panel and has to go to the switch. This is a GM coded wiring harness and to their ignition switch, it goes to the (IGN) terminal. . Any ideas of what terminal that would be according to the first switch picture above? It appears that it goes to the (S) terminal according my 66 wiring diagram which would have been a pink wire originally. (B) terminal would be (ignition power) and (A) terminal would be ( ignition switch accessory) I show nothing going to (R) terminal along with nothing going to (P) terminal which I already know that is left empty.
Old Mar 10, 2015 | 10:20 PM
NumberDummy
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37) / Obsolete ~ Available NOS & from auto parts stores.
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
Applications: 1960/70 all FoMoCo vehicles.
Old Mar 11, 2015 | 06:49 PM
bphirt1's Avatar
bphirt1
Sorry Numberdummy, I am new to the site as I just got the truck. This all new to me. Used to working on fox body mustangs. I am trying to figure out your post but having a hard time. I have been putting hours into wiring the Street Rod wiring harness and stressed. It is a GM color coded harness and the wording is different than Ford's. Am I correct on my previous post? Any help will go a long way. Thanks
Old Mar 11, 2015 | 09:34 PM
NumberDummy
This is the original pink (resistor wire-ignition coil) you mentioned in post 6.
Old Oct 7, 2016 | 11:05 AM
wfo1955's Avatar
wfo1955
Is this schematic the same for a 62'?
Old Sep 22, 2020 | 09:52 AM
Noah Schefer's Avatar
Noah Schefer
Okay so it’s not the same year but it’s similar
JEFFFAFA
37
May 7, 2018 07:52 PM
F100 '64
Oct 10, 2017 07:51 PM
rebel33382
Oct 19, 2012 01:18 AM
F250GH
Jan 6, 2009 05:47 PM
