Another IDI project, Just what I need!
Well I set out looking for a plow setup for my '93 F250 and ended up finding a good Curtis plow that came with a truck! LOL. It's a 1990 F350, ZF5, and for some reason it has a 6.9 in it. It also has Banks turbo on it. This old truck is rough and is gonna need some work. I don't really care how it looks cause I'm just gonna plow and pull mowers around with it so I'm not gonna worry about the body. It needs glow plugs or a GP relay or both, definitely needs return lines, they are leaking bad. Those issues are no big deal and a cheap fix. The main issue is the clutch. The kid I got if from said he was coming home from plowing the other day and as he went to stop at a red light, the clutch master or slave "blew a seal". If you push the clutch pedal all the way against the floor, it will barely disengage enough to be able to stop without killing the engine. Once you get it going and driving down the road, it shifts with no grinding or anything. I'm not actually sure if the problem is with the master/slave or if it's the clutch itself. What do you guys think? On a good note, the old 6.9 runs and sounds great!
The fluid level would be a good place to start! LOL. I didn't even look at it, I just drove it enough to pull it up on the trailer and back it off when I got it home. I'll check that first.
Make sure you pull the rubber plug after you pull the cap, or else you'll just pour fluid everywhere like I did, whoops
My slave cylinder went out and the truck wouldn't go into gear when running, I noticed it was starting to go because the pedal started going to the floor and not do anything clutch related
Make sure you pull the rubber plug after you pull the cap, or else you'll just pour fluid everywhere like I did, whoops My slave cylinder went out and the truck wouldn't go into gear when running, I noticed it was starting to go because the pedal started going to the floor and not do anything clutch related
Received 3,108 Likes
on
That's another good possibility, this old truck does have its share of road cancer. If that is it, what are some fixes for it?
on
Diesel 724
20
03-17-2014 02:50 PM
Pearlwhite94
09-26-2008 06:20 PM
NeoCowboy
03-14-2007 04:01 PM
sritzau
03-19-2003 08:57 PM
