Advice needed for rear diff cover
Old Mar 8, 2015 | 07:09 PM
GocartMozart's Avatar
GocartMozart
Ok, I read all the forums about changing the gear oil in rear diff. Seemed like a pretty straight forward affair. Before I removed the cover I tried to free fill plug and VSS access in order to MAKE SURE I could fill it back up (like I said I read all the forums). I encountered the typical problems: fill plug is rusted solidly into place, nothing short of a tactical nuke will free that bad boy. No way that is coming out. Then tried the VSS. Seems like previous owner tried that also and stripped (and I mean rounded) the bolt.
There are some aftermarket covers with both Fill plugs and drain plugs. Here are two I am looking at (anyone else have any experience using these?):
http://www.amazon.com/G2-Axle-Gear-40-2013AL-Differential/dp/B004PHNKUQ http://www.amazon.com/G2-Axle-Gear-40-2013AL-Differential/dp/B004PHNKUQ
and
American Rebel Outlaw Xtreme Sandblasted Diff Cover Ford 8.8
Old Mar 8, 2015 | 07:18 PM
Diesel_Brad's Avatar
Diesel_Brad
How about heat the housing with a torch, that will loosen the fill plug
Old Mar 8, 2015 | 07:49 PM
GocartMozart
I'm afraid not much luck there either. Not sure the gear oil was ever changed. Probably looks like Hershey's Chocolate Syrup/ That puppy is stuck but good. Plus, I like the idea of having a fill and drain plug for the future (thinking ahead).
Old Mar 9, 2015 | 04:12 AM
Diesel_Brad
Did you heat the housing glowing red?
VaFordman26
Jul 5, 2014 02:33 PM
GSCPSD
13
Jun 12, 2012 06:28 PM
Mike8623
Jul 31, 2007 03:24 PM
pole9cat
Mar 6, 2007 07:55 PM
maxt
1978 - 1996 Big Bronco
Feb 14, 2005 07:14 PM
