1995 Air Injection Issue
Old Mar 8, 2015 | 04:54 PM
1Austin112's Avatar
1Austin112
So first off my secondary air injection check valve had broken before i bought the truck and didn't know. I finally got a new one after searching and waiting for a warm day to replace it, went to take the rest of the broken one off and the crossover pipe snapped in half...go figure. I found a replacement crossover but my issue is i can not get the old one off, the bolts are ridiculously tight and i actually bent a wench(cheap old one) trying to loosen it. My question would be what is the harm in a few things, A. Leaving it how it is, broken in half. B. Running a rubber hose from the two broken ends of the pipe as a redneck make shift fix. C. Capping it off the right way. Or if anyone has any suggestions on how to get the bolts off. There is very little room for a socket or anything to get to the bolts which makes it even harder....Anyone provide some advice?
Thanks
(1995 Ford F-150 V8 5.0 302 XLT )
Old Mar 8, 2015 | 06:07 PM
Conanski's Avatar
Conanski
You can't leave it open that constitutes a large air leak in the exhaust upstream of the O2 sensors which will cause serious engine issues. So anything you can do to seal the system up including adding some rubber hose to reconnect the system(it would have to be silicon hose actually as the exhaust gasses are still very hot), or best of all get the broken bits off and install the new crossover tube.
Old May 2, 2020 | 01:40 PM
93 Blue's Avatar
93 Blue
Broken Secondary Air Injection Pipe
Thanks
I know this is an older post but I am dealing with the same issue on a 1993 302. Do you remember how you resolved this? Were you able to get the bolts out of the head? Did you access them from top or bottom, or one from each? If not, did you use silicone hose? Anything you wish you would have done differently? Any help would be appreciated.
Thanks
Roger
Rustyol79
Jan 4, 2018 07:57 PM
dmp944
Apr 1, 2013 04:15 PM
barryf
Oct 16, 2011 12:16 PM
Dutch123
1978 - 1996 Big Bronco
Jul 10, 2003 08:17 AM
scoobydope
Bronco II
Aug 11, 2002 12:37 PM
