95 ranger 4x4
Old Mar 8, 2015 | 11:09 AM
guyroberts68's Avatar
guyroberts68
95 ranger 4x4
I have been working on my ranger for a while, and I need a transmission. I can not find a good used automatic, but I found a 90 manual, and was wondering if it would work?
any help or advice would be apriciated
Old Mar 9, 2015 | 03:15 PM
f5fordgirl's Avatar
f5fordgirl
Might work, depending on what engine you have, and what engine the trans was bolted to. You also need a lot of other things to make it fit and work, both petals, master cyl and line, your t case may or may not bolt to it, drive shaft may be longer or shorter.
Old Mar 12, 2015 | 08:17 PM
guyroberts68
I knew about the other parts I will need. wanted to eventually do a manual swap. but the over all length is some thing to think about and the transfer case.
thanks
jerseyjew
Nov 1, 2007 12:15 PM
Madmike33
Apr 10, 2007 02:28 PM
lazzy8
Feb 19, 2007 05:14 AM
RangerGirl
Dec 13, 2006 07:28 AM
rig_pig30
Aug 14, 2005 08:58 PM
