95 ranger 4x4
I have been working on my ranger for a while, and I need a transmission. I can not find a good used automatic, but I found a 90 manual, and was wondering if it would work?
any help or advice would be apriciated |
Might work, depending on what engine you have, and what engine the trans was bolted to. You also need a lot of other things to make it fit and work, both petals, master cyl and line, your t case may or may not bolt to it, drive shaft may be longer or shorter.
I knew about the other parts I will need. wanted to eventually do a manual swap. but the over all length is some thing to think about and the transfer case.
thanks:-X22 |
