4x4 problems.
Old Mar 7, 2015 | 12:00 AM
hick51's Avatar
hick51
4x4 problems.
Here is my problem:
I drove to Durango last week in the snow, no problem in the snow and ice with the 4x4 {except ending up in a bank one time} Parked the truck for 3 days of snowboarding. 5 minutes into the drive down the mountain I hear what sounds like grinding gears and or maybe a bad gear mesh. The sounds and drag that is put on the truck is only present when off the throttle, much more noticeable above 30 mph. I took it out of 4x4 sound is gone, no drag. Put it in low range same sound and drag present.
Driver and passenger u-joints and both front drive shaft universal joints "Look OK" no obvious signs of damage.
I have manual locking hubs and manual 4x4 shift in my 2000 F250 7.3L
Front differential has never been serviced nor the transfer case.
any thoughts.
Old Mar 7, 2015 | 03:49 AM
Kamstutz's Avatar
Kamstutz
Could be a bad spindle bearing in the hub. Have you ever took the hub off and greased them?
Old Mar 7, 2015 | 10:06 AM
hick51's Avatar
hick51
no I haven't. Do is that the most logical place to start? im not to concerned right now since it only acts up in four wheel drive so when i do dive into it i would like to do it as systemic as possible.
Old Mar 7, 2015 | 01:26 PM
Kamstutz's Avatar
Kamstutz
How long have you had this truck and how many miles is on it? Even if it's not the hub spindles it's probably time to lube them.
kyle j
32
Dec 6, 2016 09:30 AM
WalkerRoberts
Apr 24, 2011 09:14 PM
jsciolla
Jan 20, 2011 11:36 AM
xr7ron
1983 - 2012 Ranger & B-Series
Jan 12, 2008 08:20 AM
BigB4000
Offroad & 4x4
May 1, 2003 11:51 PM
