winter oil recommendations
Old Feb 28, 2015 | 09:14 AM
exbxtoy's Avatar
exbxtoy
This will be my first oil change I am doing on my relatively new to me 2003 Excursion 7.3l. I'm going to add either an ez oil drain or Fumoto. Oppinons? I spoke to a couple different Ford Dealers, and they both recommended different oil weights for the winter. I am in Grand Rapids, MI, and we really have not seen temps above 10 degrees for the last several weeks. Also, please give me your advice on the brand for oil and filter.
Thanks!
Old Feb 28, 2015 | 10:01 AM
cj45lc's Avatar
cj45lc
Full synthetic 5w40 makes a big difference starting the engine in the cold temps in my truck. I buy the Valvoline at NAPA, they have it on sale a couple of times a year for $19.99 a gallon. The Fumoto has been on mine for a few years & has not leaked so I believe it's a good idea. I always get the Motorcraft oil filter at Wal-Mart for $10
Old Feb 28, 2015 | 10:24 AM
DieselDenny's Avatar
DieselDenny
I'm just North of you in Tawas, Michigan. I feel the winter blues brother!!
I run 5w40 T6 Rotella synthetic with a fram UltraGuard filter.
Just did my change last week. Walmart 20 bucks a gallon and 14 for the filter.
You'll notice a huge difference on cold starts.
Denny
Old Feb 28, 2015 | 11:36 AM
white Buffalo's Avatar
white Buffalo
Yep, diesel rated 5W-40 results in much better cold starts over 15W-40. Motorcraft 10W-30 diesel was Excellent as well.
Fumoto drain valves work great IMO. Have had one on my F-250 for 10 years.
Old Feb 28, 2015 | 12:39 PM
F250_'s Avatar
F250_
CJ-4 5w40 full synthetic... ALL YEAR!!
Old Feb 28, 2015 | 02:25 PM
bleeds blue's Avatar
bleeds blue
Denny
Im in the same boat. I switched to Rotella 5w40 full synthetic several years ago on my last truck. I will NEVER go back. It just runs SO much better with the synthetic. Cold starts are smoother and the engine will actually run without letting it warm up for an hour.
Old Mar 1, 2015 | 07:13 AM
exbxtoy's Avatar
exbxtoy
Thanks guys, anything to help beat this cold is much appreciated!
Old Mar 1, 2015 | 11:14 AM
exbxtoy's Avatar
exbxtoy
Do you run this year round?
Old Mar 1, 2015 | 11:18 AM
cj45lc's Avatar
cj45lc
quite a few folks do
Old Mar 1, 2015 | 11:23 AM
crop harvester's Avatar
crop harvester
Most people that buy in to full syn. oil,like Myself, run it year around.
Old Mar 1, 2015 | 07:22 PM
skinner24's Avatar
skinner24
I switched to 5W40 Rotella T6 Synthetic last winter after my 01' had the romps on really cold days. (Didn't plug it in all the time) I have continued to run it year round in that truck along with the 03' I purchased in Jan. of this year.
I have sent in several oil samples on my 01' to Blackstone with great reports being sent back. After sending the last one in at 9,000 they told me that I could run it for 11,000 miles.
It's more expensive but the engine is quieter and it runs better.
JMO
Old Mar 2, 2015 | 09:24 PM
husker's Avatar
husker
I also run Rotella T6 year around. Before making the change a few years back, I would get the romps on really cold days. I run it year around and change oil about once a year as my mileage is about 6000 per year. We get the best of both worlds down here. Below zero in the winter and above 100 in the summer.
BTW, I'm in Kansas, but have a daughter in Grand Haven, MI.
Old Mar 4, 2015 | 01:41 PM
sledhead999's Avatar
sledhead999
I had been running Valvoline Premium Blue 15w-40 semi synthetic. It also had the romps when cold starting. I switch this year to Rotella T6 in the 5w-40. Its soooo much better. I will continue to run it year round also!!
Old Mar 4, 2015 | 01:51 PM
exbxtoy's Avatar
exbxtoy
Thanks for all your input, I found Rotella T6 full synthetic at wall mart for 19.99/gallon!
Old Mar 5, 2015 | 08:49 AM
bleeds blue
Sorry for the late return. I do run it year round. I only put 5K on my truck last year. I would still pay the difference if I had to change it a couple of times a year.
