Engine stalling/ dying
Old Mar 6, 2015 | 09:50 AM
al0311's Avatar
al0311
so I was driving today and while at a stop light the engine just died. No rough idling or anything just cut off. Started right back up started driving then it seemed like it lost some power. No codes lights all worked when it was off. Is this signs of a bad cps ? Or something worse. Btw it's freezing cold here in PA Prob about 15 out maybe less. Don't know if this matters. 2001 f250 7.3 163,000
Old Mar 6, 2015 | 10:12 AM
Pitcrw6's Avatar
Pitcrw6
Can be a CPS. Did u ck your oil level? What did you use to ck codes?
Old Mar 6, 2015 | 10:20 AM
al0311's Avatar
al0311
I'll check the oil when I get home again today I need to change it pretty dirty. When I say no codes I mean when it died the check engine light didn't come on at all. Should I have pulled over and checked it if it does it again ?
My friend works at ford, better with gas than diesel, and has the code reader their. He ran it the other day and nothing came up, but then again no service engine light was on.
Suggestions ?
Old Mar 6, 2015 | 10:28 AM
Pikachu's Avatar
Pikachu
Dying like the key was shut off, then restarting with no issues can definitely be a symptom of a cam position sensor on its way out. Sometimes they'll set a DTC, but often they won't. Throw the spare you have in your glove box in it . . .
Old Mar 6, 2015 | 10:34 AM
al0311's Avatar
al0311
Yeah I need to go get some more lol. Do you think that would cause a loss of power post start up as well?
Old Mar 6, 2015 | 11:36 AM
Pitcrw6's Avatar
Pitcrw6
Have your buddy pickup a cps for you and throw it in. He should be able to get it under $20. When you say loss of power do you mean the eng is stumbling/hesitating or just gutless
Old Mar 6, 2015 | 11:40 AM
al0311's Avatar
al0311
I would say more hesitating. I push the accelerator but it just seemed delayed, then felt like power loss. Very odd. Iam sure it will happen again so I can describe it better.
Old Mar 6, 2015 | 05:56 PM
Pitcrw6's Avatar
Pitcrw6
There are so many things that can cause hesitation. I would fix one problem first and then move to the next.
J-P-A
28
Dec 20, 2017 09:58 PM
Dr. Johnson
Aug 29, 2014 06:09 AM
smoky_diesel
Jul 20, 2011 07:30 PM
jasvid
Oct 20, 2009 10:27 AM
kg1d
Aug 25, 2005 05:31 PM
