Sponsored by: Real Truck
Multi-Camera Setup for Towing
Old Mar 6, 2015 | 02:29 PM
TheHern's Avatar
TheHern
So...for my setup w/out the RV (or while hooking up to it):
Something like this to add into the 3rd brake light:
http://www.ebay.com/itm/120-wide-view-angle-1-4-CMOS-Smallest-Waterproof-Car-Rear-View-Reverse-Camera/290859166013?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20141212152715%26meid%3D8cc590a83b6a49eebd8a17de9b802808%26pid%3D100338%26rk%3D2%26rkt%3D8%26sd%3D231461188001
And something like this to replace the OEM camera since i'll be removing my tailgate:
http://www.ebay.com/itm/Car-Color-Rear-View-Camera-License-Plate-Mount-Night-Vision-Reverse-Back-up-LED/281434831116?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20141212152715%26meid%3Da43c7a3abedf41b8b0935e471e822d3c%26pid%3D100338%26rk%3D8%26rkt%3D30%26sd%3D111315838525
I'll wait on getting the actual license plate camera until I get the new truck here, can do some measurements, and stare at the back end for a while to see how I want it to look.
Old Mar 6, 2015 | 02:36 PM
Just Strokin's Avatar
Just Strokin
Originally Posted by TheHern
This Canopener doesn't work with the 2013-2015 Radio. The 2013-2015 radio is modular. The lockpicks for it have one connector that plugs into the head and then truck connector plugs into the lockpick cable.
This is for the older brick radio with the harddrive. This is for the radio in the 2011-2012 like in the pic below.
Old Mar 6, 2015 | 02:41 PM
TheHern's Avatar
TheHern
ok...might have screwed up here...
the CANopener is only for HDD based for navi...not the mytouch...sorry about that.
Looks like LockPick is the only way to go for the newer models.
Old Mar 6, 2015 | 02:43 PM
SavageNFS's Avatar
SavageNFS
Originally Posted by Big-Foot
Only one problem with this system that I can see... Notice the headlights on the ATV are pointed toward the curb? In the screen, they are pointed in the opposite direction...
Need a camera or screen that reverses the image in order to use effectively as a rear view mirror like this one..
That's two different pics. One's in his driveway and the other is not. The camera is right. He just loaded his ATV's opposite.
Old Mar 6, 2015 | 02:52 PM
TheHern's Avatar
TheHern
You beat me by 5 minutes noticing that!!
Old Mar 6, 2015 | 09:32 PM
Big-Foot's Avatar
Big-Foot
The camera and monitor are right.. The ATV's are loaded in the same direction. His setup is correct in that it reverses the picture.
If you had not reversed the picture, it would not be a mirror image. That's the problem you will find with a system that was not meant to be a backup (mirror) camera...
Here's an experiment for you.
Stand in front of a car parked at the curb facing it ( you are looking at the front end )...
Take a picture of it with your phone.
Now Turn around and face the same direction as the car.
Look at the picture you just took as though it were a rear view mirror.
Where is the curb in the picture (mirror)?
Yep - it's on the wrong side...
So that's why you can't use just any camera / monitor combination.
Old Dec 19, 2017 | 12:52 AM
Hunter6146's Avatar
Hunter6146
this is what i’m getting.
https://www.adcmobile.com/product/mu...d-4-or-8-inch/
12F350
Nov 20, 2017 12:23 AM
Diamnd1
Nov 24, 2015 08:28 PM
glsurratt
May 22, 2015 04:05 PM
sredmyer
Oct 28, 2011 12:07 PM
crum71
30
May 12, 2009 01:33 PM
