Frustrated any tips?
Old Mar 4, 2015 | 09:41 PM
spudman89's Avatar
spudman89
I've got an 89 f-350 with a 351w. For the last 3-4 weeks it's had a spit and sputter to it loss of power just irritating as all get out. I've changed the plugs and wires and cap and rotor air and fuel filters and cleaned the idle air control valve...it's helped but still acts up when accelerating. It idles just fine but even just running at quarter throttle it will break up like it's not getting fuel properly.
Old Mar 4, 2015 | 09:45 PM
Jaime74656's Avatar
Jaime74656
have you checked fuel pressure? maybe a bad fuel pump? did you mess with the timing any?
Old Mar 5, 2015 | 08:37 AM
Conanski's Avatar
Conanski
Is it possible the cat converter has become clogged up? If it's been removed or gutted then obviously this isn't the problem, so look into fuel pressure or a misfire with the ignition system. Check codes too as that may hint at the source of the problem, a failing PIP module in the distributor or the TFI ignition module can also produce these symptoms and should set a code.
Old Mar 6, 2015 | 12:50 AM
spudman89's Avatar
spudman89
Tonight on my way home from work it wasn't carrying on like usual however it Is the coldest it's been in awhile. But when I shifted it acted like the throttle was sticking slightly and only for very short time I pulled the dipstick and there is definitely some gas in the oil pan like its getting too much fuel...fpr or something along those lines?
Old Mar 6, 2015 | 12:59 AM
spudman89's Avatar
spudman89
And yes sir both cats are gutted with older style glass packs turned backwards so basically dual straights all the way back makes for better bank disgnostics lol
OlePOS#17
28
Aug 17, 2013 07:48 AM
geraldo14
19
May 25, 2008 08:15 PM
fordinmudd
Electrical Systems/Wiring
Dec 1, 2007 07:43 PM
FarmForward
Apr 22, 2006 03:06 AM
low92flareside
26
Apr 29, 2004 10:24 PM
