Tires
Old Mar 3, 2015 | 06:16 PM
Turtle6688's Avatar
Turtle6688
Tires
Found these tire on CL and thought they were a really good deal. What's your guys opinion on these? Also they would mount up to my Ex, right?
Tires on Craigslist
Old Mar 3, 2015 | 06:39 PM
ExploringNH's Avatar
ExploringNH
Those tires are OLD. Check the dates and check for dry rot. They haven't even made those tires in several years.
The tread on those gets hard as a rock when they get old. That means terrible traction but it also means they last a LONG time.
Old Mar 3, 2015 | 06:40 PM
Turtle6688's Avatar
Turtle6688
Thanks for the heads up. Ill look for signs of dry rot when I go to check them out.
Old Mar 3, 2015 | 06:43 PM
LivingLarge's Avatar
LivingLarge
Tires on Craigslist
What lift do you have ?
Old Mar 3, 2015 | 06:56 PM
holeshotwalt's Avatar
holeshotwalt
Also these are 16.5" rims... so they may be 8x6.5 bolt pattern as was used on pre '99 Fords. Take a measuring tool with ya!
Old Mar 3, 2015 | 07:02 PM
Turtle6688's Avatar
Turtle6688
No lift yet, but planning on 6 inch lift.
He said they came off an 04 but I'll bring something just incase.
Old Mar 5, 2015 | 09:46 PM
Immortal_Ben's Avatar
Immortal_Ben
16.5 inch wheels really limit your tire options. Hardly anyone makes tires to fit them anymore. I say tis no bueno.
Old Mar 5, 2015 | 10:39 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
x2, the initial cost may be lower but in the long run a 16" or 17" wheel and tire combo will be far easier on the wallet across the board.
Those tread lugs are also completely devoid of any siping whatsoever which means pretty terrible wet traction - especially on decent speed curves with the weight up front on your rig, even with the V10. I would steer clear and find a newer set of tires for sure. Be sure to check dates on whatever you're looking at, even good tread on a 6-7 yr old tire give you a year left of safe usable service life.
jleal_21
Jan 22, 2012 08:43 PM
Ervie
54
Dec 16, 2007 10:50 PM
alfama351
Jul 5, 2006 06:14 PM
rvanv
1983 - 2012 Ranger & B-Series
20
Sep 24, 2004 08:03 PM
mj
Offroad & 4x4
13
Apr 11, 2001 02:01 PM
