My 428 refresh...
Old Mar 3, 2015 | 03:39 PM
Osiyo59's Avatar
Osiyo59
My 428 refresh...
So I picked up a 66 F250 from a storage yard lien sale. I paid $300 for the truck. It was a little beat but solid with the only rust in the nose of the hood. I thought it was a 390 in it and was debating on yanking it to install a 5.8 EFI with an AOD. It ran decent so I decided to hold on to the FE for a bit and just refresh the gaskets because it was covered with oil and sludge and I hate dirty engines. I pulled the intake and heads and measured the bore and stroke jist to know what I had. So it turns out it is a 67 428. That made me want to go a little further with the refresh. So here is what the plans are. Pretty basic bolt on upgrades.
1. Heads are C7AE-A. Rebuild with hardened seats and new guides and seals. Air manifold holes will be plugged.
2. Short block will be left alone for now with stock internals. It run good before I tore into it so no need to spend the money right now.
3. Edelbrock Streetmaster 390 single plane intake.
4. Holley 670 Street Avenger 4v carby.
5. Edelbrock high flow water pump.
6. Long tube headers, dual exhaust with an X pipe.
7. C6 trans will get new seals, filter and a shift kit.
8 Dana60 4:10 LS gets new seals.
Please feel to chime in and let me know how you think this combination of parts will do in my F250.
Old Mar 3, 2015 | 03:55 PM
bryyce62's Avatar
bryyce62
Me thinks that you may want to reconsider your single plane manifold for a dual plane. Unless you're building a race truck, that is.
Intake Manifolds: Single Plane or Dual Plane? - EngineLabs
Old Mar 3, 2015 | 04:15 PM
85e150's Avatar
85e150
Google the Streetmaster and find a lot of folks like it on the FE.
You could go with more carb but that carb will work fine.
Old Mar 3, 2015 | 04:51 PM
Osiyo59's Avatar
Osiyo59
Thanks Bryyce62, I had read that article before I bought the Streetmaster. I had a choice between that and an F427 intake for the same price. I went with the single plane based on 2 factors. It seemed to get better reviews for overal performance as a bolt on intake but the other is I am eventually going to convert it it an EFI intake utilizing the EFI from a 1996 7.5L (460). A dual plane won't work for the conversion.
Old Mar 4, 2015 | 09:06 AM
MIKES 68 F100's Avatar
MIKES 68 F100
congrats on the 428 discovery
be sure to post a thread for that EFI conversion !!!
Old Mar 4, 2015 | 12:23 PM
Osiyo59's Avatar
Osiyo59
I will mike but don't hold your breath. It'll be while. Just getting this truck mechanically sound so I can focus on my F100 DOHC project.
Old Mar 5, 2015 | 06:01 PM
Osiyo59's Avatar
Osiyo59
Anyone know what the specs would be for a stock 428 camshaft in 1967?
Old Mar 5, 2015 | 08:53 PM
85e150's Avatar
85e150
Standard 428 same as a 390 car engine:
FE Engine Camshaft Specifications
16
Feb 16, 2008 09:44 AM
Gear Up
17
Mar 26, 2006 11:45 AM
BOSSv10
Feb 1, 2006 07:26 PM
Gunfighter398
May 10, 2005 08:54 PM
Jag Red 54
Oct 11, 2004 06:42 PM
