Brain storming battery charging
When do you use the battery bank? What is it's purpose?
You could do what you propose, but you would lose some efficiency in the charging process. The motor would not be 100% efficient, and you would lose some power in the v-belts and the alternator. But it all depends on how you are using the system. If you use the generator for 4 hours each day for other purposes, and it has plenty of reserve, I guess it would not matter too much.
You do want to make sure and charge the batteries fully once in awhile for max life. I am assuming you are using the batteries at 12v and they are all in parallel?
So I did a little maintence on the batteries and one was pretty low on water, topped them all out and we'll see if that helps. Also the new Shumacker charger has different settings than the old (dump) charger. I had it set for 6/2 amps and plan on testing it on the 10 amp setting but don't know if that setting has an automatic amp drop when charged. It will get sorted out I guess. But keeping in mind that every hour the gen runs costs about $1.00 and every hour the battery bank supplies our needs saves about $1.00 so you can see our battery power saves in the long run.
So, now getting back to the alternator question....I'm pondering if by not using a "battery charger" and switching to an electric motor driven alternator (I'm pretty handy at building stuff like a frame for the system) that is plugged into the generator (that is running anyhow) if that would charge the batteries faster. My theory is that we all know that it only takes a short drive to charge a low battery in a car....and a long time with a charger so treat these deep cycles like they are in a car. Make any sense?
Most motors are around 1800rpm or 3600rpm.
If it's a case of you already having a motor laying around, either one would probably work. But you need to figure on the horsepower needed to turn the alternator. It may turn out you will need a pretty big motor to turn the alternator, and then you would have to juggle that with the load on the generator. To use a smaller motor, you could use a pulley on the alternator twice the size of the pulley on the motor. That would reduce the load on the motor, but also reduce the alternator output.
You don't get something for nothing in this setup. Case in point, your batteries may not be exactly giving you "free" power. The generator may only cost 75 cents and hour to run if you are not charging the batteries.
They say solar panels are coming down in price. Have you looked into that to charge the batteries? I wonder what the pay-off on those would be? $3 dollars a day to charge the batteries, that's about $900 per year?
But you have a HUGE battery with four "cells" in parallel. A standard 4 or 6 amp automotive charger won't cut it, (maybe as a float charge) as you've discovered. It would take day(s) to bring them up, It will work but you'll end up in the bulk and absorption stages for waaay too long and cause excessive outgassing. It's not "sized" right for efficiency or battery chemistry.
A 50 or 75 amp charger is probably closer to a "slow" rate and get things going in a reasonable amount of time, and not warp plates from excessive current. That large of a battery needs some serious juice to get back up to 100%.
Remember an alternators job is to simply recharge the energy loss from a second's worth of starting. Auto start battery application is different than what you want to do.
Heavily or completely discharged deep cycle batts wired in parallel, any "normal" alternator would get roasted in short order I reckon because it will be maxxed out for hours at a time every time. What you want to do is determine the total AH capacity of your battery bank, (not CCA) by adding up each "cell" of your bank and figure on applying no more than about 20 percent of that figure as a recharge rate. That will be a big number on a big charger.
If just replacing the charger is the goal what you need to look into is a converter. Really another name for a charger but higher amperage and popular in the RV world. For example the one I have would likely be prefect. It's 40 Amps, controls for charge and voltage as well as a desulfation mode. Got it used for $40, kicks any typical chargers ****.
However what IMO you should do is kind of along the lines of your AC motor to alternator idea. Put together a quite small engine and an old school vehicle generator. Not alternator, generator, one off an air cooled VW would likely be cheap, common, and work well. This setup would be MUCH more efficient and could be run for very long hours at quite low fuel cost to constantly charge the batteries. This would remove the need for a charger/converter and running time on the AC generator to charge the batteries, a very inefficient method. Allowing you to only run the generator for when your running your larger AC draws during the work day.
Why a generator and not an alternator, they are much more efficient. The reason alternators are used in vehicles is that they charge better at low RPMS. But the low RPM attribute wouldn't be a need for a stand alone unit, you would set it up to run at a rather constant RPM where a DC generator is more efficient.
More I think about it the VW generator idea is pretty good. VW generators are common, cheap, parts are easy, and mechanical voltage regulators are still available(I think). Also they are pedestal mounted, they mount in an aluminum pedestal that just bolts to the block, get a stock pedestal and you cold bolt it to anything. The pulley is unique in that it is also a tensioner, the two halves of the pulley come apart and shims are placed between the two halves to adjust tension. A very good setup for a solidly mounted generator and engine. Last they are through shaft, stock one side is a pulley and the other a fan. Where the fan would mount gives you options.
The mechanical coils and points regulator could be rather handy to. If someone was clever one could be used to activate a solenoid to increase engine RPM when voltage drops.
Damn think I'll build one.
Another idea, I assume heat is an issue much of the year and at night, assuming you use propane or something for heat. Well the stock fan on the back of a VW alternator is the cooling fan for the engine. Use a VW fan shroud, likely a type 3 would work best. Use it to blow air over the air cooled engine for heat. Being careful about exhaust of course.
Some interesting reading, a member here made something along these lines for portable 12V power but using a 130A alternator. https://www.ford-trucks.com/forums/1...y-charger.html
I do have a question, do you think if running a vw gen to the battery bank it would charge the batteries to keep them up enough if pulling minimal power to the Hitchhiker? Otherwise I'm leaning towards an electric motor/gen to "charge" the bank while the 4000 gen is running. I checked out some of the higher tech "inverters" and it seems like the $40 find was a bargain. I read the thread you posted above and never knew that alternators needed (consumed) so much horsepower....that's an eyeopener. I've got at least ten various 5 to 6.5 horsepower Hondas used for gold dredges too post hole augers and would have thought that they would be "over-kill for a simple little alternator.
After a little troubleshooting I figured out what setting to use with the new charger and we now run the puppy (4000 generator) for about three hours and the batteries supply about two to two and a half hours so that's not so bad. I've also noticed that the batteries don't hold much of a charge overnite so it's time to cash in some gold dust for four new deepcycles, ha! I also will check the water level more often, enough said about that....
I have researched ALOT about solar panels (even make it yourself ones) but these dang two hundred foot doug fir trees surrounding us pretty much eliminates that idea....just not enough sun in the winter time to justify the cost.
Don't be timid about adding comments to this thread.....it's all good info., the suns shining and the bees and frogs are everywhere.
$40 is a fantastic deal for a good inverter or converter(if that's what you meant) I was secretly jumping for joy on the inside when I bought mine. I suggest keeping an eye out on places like craigslist for people getting rid of broken trashed or whatever RVs. There are plenty of people with old trashed RVs that don't know the value of the inverter/converter.
It makes since when you think about how an alternator works. An alternator is basically a 3 phase AC generator with a rectifier(a set of diodes) to make it output DC. Because of this half the energy is stopped by the diodes and made into heat. A 12V 130Amp alternator would take the same power to turn as a 12V 260Amp 3 phase generator.
I think one of your 5HP engines you have around could VERY easily run a VW generator though.
Probably a good deal, and probably could get it as low as $100 with sales and coupons. But it's still just 45 Watts and that's when it has full sun. Watts is Amps times Volts. So 45W at 12.6 volts is only 3.57 Amps. So you'd need 3 of those kits to provide the same amperage as your 10 amp charger.
First Amps, Watts, and HP. A stock VW generator is rated at 30 Amps peak. If that's at a high of 14V that's 420 Watts. 1HP = 746 Watts. Now Josh did this same math when he made his. But here I think it's safe to say a generator will be at least 60% efficient. If so it only takes 1HP to turn it, I'd error higher and plan on a 1.5HP minimum. Several reasons, engine inefficiency, drive system drag, and so the engine doesn't need to run at high RPMS. Of course this all changes if you leave the fan on.
Drive, my first choice I think would be bicycle parts. Chains are more efficient, parts are cheap and a wide range of ratios are readily available. This would include using a rear derailleur. Mostly because it's also a chain tensioner, however if a rear multiple sprocket setup is used it would make a change in ratio very easy. Stock I think is about 2:1 so I think that should be a minimum overdrive.
I haven't quite worked out the details of using a voltage regulator to adjust engine throttle/speed. I need to ponder the internal workings of the voltage regulator. However I'm confident a rather simple two stage setup could be setup. Two voltage regulators would be used, one setup normally to adjust the field. The second used to trigger a high speed idle solenoid off an older vehicle. One like is used to speed up the idle with AC, or on a diesel for cold start. The two stages would need to be adjusted based on how it's setup. But basically the regulator throttle setup would work in 4 stages. The first three stages all at low throttle and typical generator setup. The fourth occurs when the high setting at low throttle isn't enough to maintain voltage. This would cause the second regulator to trip on the high throttle solenoid.
The bicycle chain is good in theory but keeping it lubed for long life might be a problem. Since you need such little horsepower, the loss with a v-belt setup might be worth the low maintenance aspect of it.
IMO small HP numbers is a reason less drag is more important. Bicycle chains are pretty darn durable and cheaply replaced. Keep a can of tri-flo near by and give a squirt when you start it in the morning, add fuel, check oil, whatever works.
