trouble codes
Old Mar 2, 2015 | 06:45 PM
blue924.9's Avatar
blue924.9
trouble codes
hey all, took a video of the codes i got this morning, wanted a 2nd opinion and set of eyes (and someone who has done this before) to confirm what codes i got.
the video i took
Old Mar 2, 2015 | 09:29 PM
subford's Avatar
subford
KOEO code DTC 111.
Continuous Memory codes DTC 327, 328 & 452.
DTC 327 & 328 says you have either bad wiring to the EVP sensor or a bad EVP sensor.
DTC 452 says you have a VSS problem. Could be a bad rear end, wiring to the VSS or a bad PSOM.
Old Mar 3, 2015 | 07:18 AM
blue924.9's Avatar
blue924.9
Thanks subford.
Any idea how to do a koer test? Oldfuelinjection.net only showed engine off tests
Old Mar 3, 2015 | 07:59 AM
subford's Avatar
subford
How To Run The Engine Running Self-Test
DO
Deactivate Self-Test.
Start and run engine at 2,000 rpm for two minutes. This action warms up the HEGO sensor.
Turn engine off, wait 10 seconds.
Activate Self-Test.
Start engine.
After the ID code, depress and release the brake pedal if appropriate. See Special Note below.
After the ID code, within 1 to 2 seconds, turn the steering wheel at least one-half turn and then release it, if appropriate. See Special Note below.
If a Dynamic Response Code occurs, perform a brief wide-open throttle (WOT).
Record all service codes displayed.
DON'T
Depress the throttle unless a Dynamic Response Code is displayed.
Engine Running Self-Test Special Notes:
On vehicles equipped with the Brake On/Off Switch (BOO), the brake pedal MUST be depressed and released AFTER the ID code.
On vehicles equipped with the Power Steering Pressure Switch (PSPS), within 1 to 2 seconds after the ID code, the steering wheel must be turned at least one-half turn and released.
On vehicles equipped with E4OD transmission, the Overdrive Cancel Switch (OCS) must be cycled after the ID code.
The Dynamic Response code is a single pulse (or a 10 code on the STAR Tester) that occurs 6-20 seconds after the engine running identification code. (See APPENDIX: «Code Output Format».)
When/if the Dynamic Response code occurs, perform a brief wide-open throttle.
Deuce40s
Oct 15, 2013 07:36 AM
SideWinder4.9l
Jul 14, 2011 07:23 AM
fkaster01
Apr 1, 2009 10:59 PM
93truck
Jun 15, 2006 09:53 PM
WALJON
Oct 23, 2004 09:11 AM
