Another DEF issue
Old Mar 1, 2015 | 03:09 PM
Joe/GA's Avatar
Joe/GA
Another DEF issue
I've seen some posts where folks let their DEF get low and got an 800 mile range warning. I had better than a half tank of DEF when I got a 500 mile range warning. Just to be sure, I got a 2 1/2 gallon container and started pouring it in. After about 2/3 of the DEF went in, the tank was full. Cranked the truck and I still have the warning. Now I'm down to 463 miles. I have about 265 miles that I need to drive tomorrow while pulling a 16,500 Lb 5th wheel camper. Will the count down be the same as not towing? Any way that I can fool the computer, like puling battery cables for 5 minutes?
Old Mar 1, 2015 | 03:26 PM
Big Red 5205's Avatar
Big Red 5205
Good Luck Joe/GA, My truck has done this to me twice. The first time, I was in the same position as you are. I live in South Florida and I was in Concord, NC at the drag races, was leaving there to go to Alabama before heading home and that is more than 500 miles. Was pulling my 18K 5er.
Went to a local dealer in Charlotte, they worked on it all day and said they fixed it. Then two weeks later it did it to me again. My local dealer had it for 4 days doing tests and could not find anything bad. Did pinpoint test and others and it cleared itself. Has not reoccured since then, now about 4 months.
I know how you feel, I did not want to on the road with a 43' trailer when the countdown got to zero.
Old Mar 1, 2015 | 03:32 PM
Joe/GA's Avatar
Joe/GA
Thanks for the reply Big Red. I remember this happening once before and it cleared itself. I went out to the truck about 30 minutes after shut down and cranked it to see if the message was still there and it is. I hope it gets me about 265 miles before it quits!
Old Mar 1, 2015 | 03:41 PM
Joe/GA's Avatar
Joe/GA
Oops. I just realized that I never corrected my signature when I traded my 2011 for a 2015. So, this issue is on a 2015 with almost 12,000 miles.
Old Mar 1, 2015 | 03:54 PM
Dakster's Avatar
Dakster
And here I thought Ford fixed this issue a long time ago...
You could try cleared codes to see if it goes away and doesn't come back. When I get a glitch in these trucks a reboot of the computers works. I have the Forescan app and a bluetooth OBDII reader. (The reader was $5 shipped from Amazon) It cured an HVAC issue in my 2011 when I was in Haines Junction, Yukon, Canada. That area makes BFE look populated. I had no A/C, No Heat, and all the blower doors were stuck shut. I used forescan to run through some tests and one of them started moving the blower doors and rebooted the computer.... It all worked normal after that.
IMHO, I think what happens is that the computer glitches and doesn't see one of the higher up sensors (there is no level gauge in the DEF tank) and the countdown begins and doesn't stop. It is messed up because you could have a FULL tank of DEF and it will strand you. You would think it would only strand you if it went to pump DEF all it got was air...
Old Mar 1, 2015 | 04:03 PM
Joe/GA's Avatar
Joe/GA
Thanks! I guess I need a Forescan app and a bluetooth OBDII reader. Do you think that pulling the battery cables would clear the code?
Old Mar 1, 2015 | 04:48 PM
Dakster's Avatar
Dakster
Probably not, but it is worth a try. Potentially an auto parts store will read and clear codes for you for free too...
Old Mar 2, 2015 | 06:51 AM
senix's Avatar
senix
I think you will be able to get to your destination but you may need to maybe pull the batteries and see if that will reset it once you arrive.
Sounds like a bad sensor since this seems to be reoccurring for you.
Old Mar 2, 2015 | 07:18 AM
Joe/GA's Avatar
Joe/GA
Thanks seeing! I hope when I crank it this morning that the warning message is gone!
Old Mar 2, 2015 | 07:19 AM
Pocket's Avatar
Pocket
Be honest.... Have you been topping it off before it gets below 1/2 tank?
Because the issue you're having is exactly what happens if the DEF tank is topped off on a regular basis without allowing it to run down at minimum below half tank. If this is the case, you'll need to take it to the dealer for a reset.
The owner's manual is very specific about how the DEF fluid must be run down prior to refill.
Old Mar 2, 2015 | 08:19 AM
FordService's Avatar
FordService
Official Ford Rep
Hi Joe/GA,
Did you see the message again this morning? I want to bring this to the attention of your regional customer service manager (CSM) so they can help. To get the ball rolling, PM me your full name, best daytime phone number, VIN, current mileage, and preferred servicing dealership. Since you're traveling, I can assign the dealership closest to your destination if you'd like; just let me know.
Crystal
Old Mar 2, 2015 | 09:16 AM
rob17's Avatar
rob17
I had the same thing happen after filling the DEF in Fargo ND, I couldn't get the DEF to show full. I decided to continue my trip to Bismarck ND. After about 50 miles into the trip I checked again and now it was showing full/OK. It's never done that again.
Rob
Old Mar 2, 2015 | 07:13 PM
azking_Ranch's Avatar
azking_Ranch
Joe/GA
I had the same thing happen with my 2015, Got the 500 mile to empty message, then tried to add a cartoon of Blue Def, the truck didn't take the full supply.
Chuck
Old Mar 2, 2015 | 07:38 PM
Rich53's Avatar
Rich53
Is the DEF frozen?
Old Mar 2, 2015 | 07:49 PM
gwcon's Avatar
gwcon
I had this happen to my '15 once. That was about 3000 miles ago and it has not been a problem since.
